Post by bluecob99 on Apr 16, 2013 21:09:22 GMT
Hi there, am l right that the R1 that the engine comes out of is the registration you will be passing on to your Tr1ke project? Or am l wrong as in most cases!!!
Post by John B on Apr 16, 2013 21:28:52 GMT
If I'm not mistaken with the tR1ke they have all been registered with a new plate as the majority of the build is with new parts (i.e if you were to test your tR1ke now it would be a 13plate). I'm not sure of the exact requirements though but you should be able to find out on the DVLA website.
Post by paulh on Apr 16, 2013 21:33:39 GMT
Chassis wheels suspension need to be new and engine "reconditioned" to register as new. Which means when you buy the kit all you need is a receipt for reconditioning and fitting new gear set
Post by Deleted on Apr 16, 2013 21:37:17 GMT
You are allowed a major part like the engine gearbox to be classed as reconditioned, then everything else has to be new or appear new, to qualify for a new plate.
Post by Paul (madeye) on Apr 16, 2013 22:01:22 GMT
if you have paperwork saying remanufactured. not reconditioned. its all in the wording
