Post by Stiggy on Apr 9, 2013 12:14:40 GMT
First the chassis is turned upside down and the alloy sheet is marked for cutting out. Note we leave 75mm overhang for attaching the sills of the body to.
Then we cut it with a jig saw.
Then we rivet it on with large head rivets supplied in the kit. These are approximately at 95mm centres.
NOTE: It is suggested that unless you have use of a car lift that you P clip the fuel lines and rear brake pipe to the inside of the chassis rail whilst it is upside down, please see further down the build blog on page 2.
Then we turn it over and drop it on the MX5 subframes with the engine/gearbox/differential/prop shaft and suspension still in place.
The pedal assembly from the MX5 is now bolted into place complete with servo and master cylinders for the clutch and brakes. The holes are per cut in the bulkhead plate. Just a hole to drill for the MX5 throttle cable.
We can now fit the standard MX5 steering column on the drop plate. This can be altered for those requiring a different steering wheel height. The steering wheel is wood look as wooden ones are not allowed for the IVA test. It has a collapsible boss too.
The front anti roll bar has mounting point s on the chassis.
Here you can see the front chassis mounting bolts fitted.
The rear subframe to chassis mounting bolts are shown here together with the rear body support frame bolted into place.
You can also see how the tops of the shock absorbers just slot through the chassis and bolt on with 2 8mm nuts each corner of the car.
Next I fitted the handbrake with the standard MX5 handbrake cables and return spring. I had drilled the holes in the tunnel prior to it being powder coated.
