Post by tomaff on Nov 17, 2012 10:30:28 GMT
So today's task is to finish the back end. Just the lights to go. However when wiring them up and following the build guide there is only one wire per light from the loom but 2 out the back to make the circuit. So where does the other wire from the light go?
Oh and I am using the mev supplied lights
T
Post by mathew on Nov 17, 2012 16:16:01 GMT
Which lights are you using?
Each light will need an earth as well as a power feed. I ended up splicing the earth feed so instead of one i had 3 each side which was enough for all my lights.
Post by stevieboy on Nov 17, 2012 19:52:14 GMT
I ran one earth from the main loom to each side and spliced all three lights into it.
Post by squelch on Nov 17, 2012 19:54:03 GMT
If its the MEV supplied lights it'll be the round Hella units each light unit has a supply and earth were as the mazda harness fits to a combined light unit so only has 1 earth for the complete light set you'll need to join the earths for the Hella lamps together and then to the earth in the Mazda harness
Post by tomaff on Nov 17, 2012 21:55:04 GMT
Got it all sorted and took it for its first drive today. Just down to the end of our garages and back. But great fun in itself. Had a custom exhaust made for the car which it is outstanding to say the least. Hoping to book iva in around 2 weeks then finish the last touches while its is waiting. Anyone know what the iva test times are like over Christmas and new year?
T
