Post by driver on Nov 15, 2012 16:30:32 GMT
Im at the stage of Installing the wiring harness back on the exocet! Im finding it really fustrating, ive made a little shelf/tray sort of thing to hide most of it in at the dash. It seems to long and taking to much space! Anyone got any pics or advice? Im not to keen On cutting and chopping the wires just yet untill i know it all works. This is by far is the worst bit of the build so far!
stubbers
Exocet Number 306
Post by stubbers on Nov 15, 2012 16:54:15 GMT
If you take a look at my build you can see the tray made from the off cuts from the floor. The whole unaltered loom fits in and then you can cut it down later to thin some of the unneeded wires out.
Rich
Post by Wayne Bale on Nov 15, 2012 21:02:59 GMT
On my mk1 I found you did not need to make a tray. Just mount the ecu in front of the console and coil up the wires underneath above the steering column. Look at my video on my balebuild. I have only removed a very few wires so most is still there.
Post by driver on Nov 16, 2012 23:08:36 GMT
Cant find your video can you post a link please?
Post by Wayne Bale on Nov 16, 2012 23:22:25 GMT
Post by stevieboy on Nov 17, 2012 19:59:52 GMT
shortening the loom is not as scary as it seems, take a lok at my build. Take all the overwrapping off, lay the loom over the car roughly where your going to put the wires, then cut each one and solder back together, i did this with no experience and only used a £7.95 solder kit off ebay. Its best to purchase some heat shrink casing to make a good job.
