Post by Stiggy on Apr 17, 2015 14:08:08 GMT
Post by huggy on Apr 18, 2015 1:09:38 GMT
Those look the same as what I've used. I bought the wiring kit with the car. Had to augment it a little however it was straight forward enough. Don't forget the relay holders. Make sure your flasher unit is compatible with your indicators e.g. a regular flasher unit might not be able to flash led indicators.
Post by huggy on Jun 30, 2015 22:19:24 GMT
Rear end wiring tidied up / cable tied and battery tray fitted. For now, just using an old battery for testing Battery cut off fitted
Post by huggy on Jun 30, 2015 22:27:10 GMT
Internal style exhaust before polishing First stage of polishing Shiny! End piece added with suitable radius for IVA Exhaust bracket fitted to engine block
Post by huggy on Jul 4, 2015 23:56:18 GMT
Exhaust fitted:
Post by huggy on Jul 24, 2015 21:58:45 GMT
Engine number stamped. Lesson learnt, do this before fitting the engine and rear bulkhead. Obvious really, but still a silly mistake I made. Couple of hours wasted as a result. Oh well.
Post by huggy on Aug 5, 2015 20:36:13 GMT
Happy times. Car started today! (note: ignore fuel line routing in video. I had the wrong way round on the fuel rail, so now need to rework and secure)
Post by nate78 on Aug 5, 2015 20:48:42 GMT
Well done. I have to say thou, you are certainly using every inch of space in your garage !! Hahaha
Post by huggy on Aug 5, 2015 21:15:21 GMT
Well done. I have to say thou, you are certainly using every inch of space in your garage !! Hahaha Cheers. Such a nice feeling once it started ticking over smoothly. It is indeed way too busy in there. What I'd give to have a double garage. Need those lotto numbers to come in :-)
Post by BobN on Aug 6, 2015 7:09:40 GMT
Almost there now. Just put the wheels on and you are ready to go.
Do you have a target completion date in mind? Mine was to have in on the road ready for Stoneleigh.
Post by huggy on Aug 6, 2015 22:58:24 GMT
Almost there now. Just put the wheels on and you are ready to go. Do you have a target completion date in mind? Mine was to have in on the road ready for Stoneleigh. Target date, hmmmm, November 2013! Well that ship has sailed! Hopefully November 2015. Should only be a matter of weeks now.
Post by huggy on Aug 13, 2015 1:39:51 GMT
A few random jobs in what I hope will be the final sprint towards completion. Fuel inertia switch fitted: Fuel pipes reworked and secured (...having mistakenly had them connected to the fuel rail the wrong way round prior to starting the engine for the first time last week): New battery: Bled brakes and clutch (...tried the one man vacuum but was not happy, so reverted to the good old two person approach): Trimmed the center tunnel and console.
Post by kiwicanfly on Aug 13, 2015 1:46:28 GMT
Burning the midnight oil Huggy?
Post by huggy on Aug 13, 2015 8:06:53 GMT
Indeed. Lost track of time :-)
Post by huggy on Aug 17, 2015 23:00:06 GMT
Rear part of center tunnel fitted Fuel tank bolted down. Pipes & cables neatened Front part of center tunnel fitted Gaiters and gear knob fitted Center console fitted
