Post by Toed64 on Jul 22, 2012 11:49:07 GMT
Hello all. Can anyone help me please. I didn't strip the original MX and I'm a bit stuck. There is a single, fairly heavy duty (2mm ish) single blue wire that comes from fuse box. On the other end it has a white plug/spade. The previous owner did not label it and I can't find a home for it - any thoughts?
Your suggestions would be very welcome.
Post by freshlikesushi on Jul 22, 2012 12:35:40 GMT
IIRC blue is the air bag wire?
white is a power wire frmo my year on all the MAIn power wires.
Post by Toed64 on Jul 22, 2012 13:02:15 GMT
IIRC blue is the air bag wire? white is a power wire from my year on all the MAIn power wires. Thanks for your thoughts... Hmm... although it was a Jap import, the original car was too early for airbags. This lead is bright sky blue and about 6 feet long. I'm fairly sure it followed the loom from the right side footwell fuse box and probably went round to the left side front loom. Could it have been power for the A/C? I have not yet found it in my Haynes manual
Post by freshlikesushi on Jul 22, 2012 13:16:12 GMT
Check the AC portion of your haynes manual
my 1990 had airbags (was a us model though)
Post by gwnwar on Jul 22, 2012 17:57:57 GMT
on early USA cars there are 3 blue(L) wires from fuse box upper right 2 down= wipers.. center of bow= heater.. top left= ? don't see were it goes...do you have the lid for the box it should be on that or in the owners manual.. does it go to a 1 wire connector?? no stripes on wire..
Post by gwnwar on Jul 22, 2012 18:00:22 GMT
Sorry..bow should be box for second fuse/wire
Post by Toed64 on Jul 22, 2012 22:16:04 GMT
on early USA cars there are 3 blue(L) wires from fuse box upper right 2 down= wipers.. center of bow= heater.. top left= ? don't see were it goes...do you have the lid for the box it should be on that or in the owners manual.. does it go to a 1 wire connector?? no stripes on wire.. Thanks so much for your input. It's a single, heavy wire, in straight mid blue (no stripes or dashes). Looking at the Haynes manual, I'm pretty sure it was for the A/C... and now I don't care so much, because I got the car started for the first time this afternoon. I had loads of electrical oddities going on, but finally I got them all sorted... I think I've got all the circuits, gauges and dash lights I'll need. So I'll remove the blue once I've checked and rechecked. Thank you both for your help
Post by gwnwar on Jul 22, 2012 23:31:41 GMT
Don't cut it to short.. leave alittle and shrink tube it in case you need a power sourse later for what ever..
Post by freshlikesushi on Jul 23, 2012 0:50:59 GMT
glad he could help. hopefully you get it sorted
