Post by kiwicanfly on Aug 10, 2012 3:00:30 GMT
That lagging looks a lot like the stuff they wrap around new bikes as well, our bike shop gave us a load to protect the wifes new bike when on the car rack
Well when I say gave, to be accurate it came with a new all carbon bike for the wife......... No I was NOT building up the brownie points in preperation for the Rocket.
I reckon thought that bike shops have loads kicking around if one asks nicely.
Post by Paul (madeye) on Aug 10, 2012 6:11:01 GMT
yep, get in there, and paying for an all carbon bike deffo means you didnt get if free..lol
Post by Paul (madeye) on Aug 12, 2012 21:32:40 GMT
todays efforts saw the arrival of my engine cover mod. its an original reynard formula 1 job. ill be cutting it approx where the rear camel is, then grafting it to the flat engine cover. cutting a hole in the cover and mounting the CDA filter in there for a good direct ram air for the charger. im pretty sure i really didnt need a genuine formula part though
Post by Paul (madeye) on Aug 13, 2012 12:38:48 GMT
here is where its meant to sit on the real car. its a nice overpriced bit of nostalgia i think.
Post by 2beers on Aug 13, 2012 18:02:07 GMT
Of course you need it!
Looking forward to see you incorporate it into your build.
Cheers, /Tobias
Post by Deleted on Aug 13, 2012 18:25:14 GMT
Very intriguing.. How much does it weigh?
ollieballs
st170 rocket tuned to 200bhp
Post by ollieballs on Aug 13, 2012 19:59:52 GMT
Sweeeeeeet! What are you planning to do to cover the rough edges at the front of the scoop? I suppose you could make the roll bar follow the line and that would look amazing! I'm glad someone's finally taking the plunge and giving this a go. How's the dry build coming along?
Post by Paul (madeye) on Aug 13, 2012 20:36:00 GMT
Sweeeeeeet! What are you planning to do to cover the rough edges at the front of the scoop? I suppose you could make the roll bar follow the line and that would look amazing! I'm glad someone's finally taking the plunge and giving this a go. How's the dry build coming along? the entire unit is 7kg-ish, ill be removing more than 50% of it though and then scribing it around the engine cover. i need to complete this before i can start the welding on the bar. the bar is gonna sit directly in front of the the outer lines of the scoop, about 5mm away. ill sketch a pic and post it up. the scoop will be removable from the engine cover and the engine cover will be removable not hinged as i dont like the piano hinge, im looking for some eccentric cam hinges to totally move the cover out of the way.. sort of like a lambo door. paul
Post by Paul (madeye) on Aug 14, 2012 8:59:04 GMT
i was a bit dubious on that weight, got some calibrated scales on the case. complete unit 4.55kg thats better, so worst case ill add 2.5 kg and a little drag, but should create some good high pressure direct ram style induction.. we shall see
Post by Paul (madeye) on Aug 16, 2012 18:46:20 GMT
got some seat rails cut today and made the gearbox mount which i needed to be longer By swordfishmartin at 2012-08-16 a fair but of difference, and took some right bloody bending, loads of heat and over 20 tonne By swordfishmartin at 2012-08-16
Post by Paul (madeye) on Aug 18, 2012 18:45:17 GMT
Post by Paul (madeye) on Aug 18, 2012 19:00:14 GMT
sorry the pics are so big, i uploaded them all bulk and it was set to 17" monitor.
Post by Paul (madeye) on Aug 19, 2012 9:18:34 GMT
i have the rear section of the engine cover if anyone wants it, its an expensive bit of memorabilia (just cut in half). free to good home, if it could be used or just kept on show. Free to good home, just postage or collection.
Post by kiwicanfly on Aug 19, 2012 10:11:35 GMT
Looking good Paul, but don't you think that all the effort with the F1 engine cover is going to be wasted if you continue to leave the spare wheel on the bonnet?
Post by Deleted on Aug 19, 2012 18:49:51 GMT
Nice fella. Don't think air intakes going to be an issue;) lol
