Post by murfeey on Jul 18, 2012 8:41:07 GMT
Have a missed out anything, engine,gbox ,prop ,rear diff,wiring loom ,steering column,pedal box,servo.petrol tank.
also when buying a donor,do you sorn it,when building the exocet,will it need sva,iva etc,sorry for all questions new to this.
if Ive missed anything can you let me know.
cheers murf.
Post by leahy on Jul 18, 2012 12:02:40 GMT
Hi,
might be obvious but speedo cable, clocks handbrake etc be careful if it has an aftermarket alarm.
Post by freshlikesushi on Jul 18, 2012 12:48:54 GMT
everything but the body.
anything else you can sell if you don tneed it, but keep it in case. INCLUDING all the fasteners you remove from the donor chassis.
Post by lukiez on Jul 19, 2012 23:38:47 GMT
Might be a no brainer, you'll need the sub-frames unless you're building the lightweight. Don't forget to retain the axles and brake etc. Basically keep all the mechanical bits and chuck the body as already mentioned and sell what's not needed.
Yes you'll need to go through IVA, you will need to Sorn it (claim any remaining tax back as a result). When scrapping the body try and get a receipt but keep the V5/logbook and cut out the VIN to keep for proof later on when its time to register it
