Post by shardy on Jul 12, 2012 9:40:55 GMT
Hi,
As discussed on adam1001s thread, has anyone who has finished their build managed to corner weight their car?
In theory it could be done to a reasonable accuracy with 3 paving slabs and a 200kg set of bathroom scales!
I'm looking at getting a suspension setup with sensible spring/bump/rebound settings and some accurate weights will help massively.
Cheers, Stuart
Post by leahy on Jul 12, 2012 12:10:43 GMT
I will be following this thread with interest. have often thought this but never asked
Post by shardy on Jul 25, 2012 19:07:24 GMT
Hi, has anyone had any joy?
Cheers, Stuart
Post by Stiggy on Jul 25, 2012 20:49:38 GMT
You could always buy 8 cheapo scales from Argos or a similar establishment, arrange them with a piece of timber so each wheel spans a pair of scales. No use unless you can adjust the spring seat on your shocks though, try it with the driver on board.
Post by adam1001 on Jul 26, 2012 1:06:16 GMT
Hmm, looks like someone's beaten us to it. There's a very attractive 'Cork platform' scale reduced at Argos from £6.99 to £2.99. Unfortunately I can only find one available and it's in Launceston.
Post by shardy on Jul 26, 2012 6:27:08 GMT
I'd love to give it a try, but my heap of bits is still pretty large... Although getting smaller by the week! Anyone else a bit further ahead?
Post by freshlikesushi on Jul 28, 2012 14:41:31 GMT
may or may not help you guys. but my parents are gona scale the car this week comming up
Post by gwnwar on Jul 28, 2012 17:27:30 GMT
Fresh.. it will give an idea but with yours just alittle heavyer in the front.. remember to have them weight the drivers seat by your weight to get a better reading.. were are you getting your springs from Pegasus has some.. when are you coming back to the states.. what class do you run with the car..
Post by freshlikesushi on Jul 29, 2012 1:02:43 GMT
i use eibach springs on BC racing coilovers im pretty happy with my current setup. once i push it a little more, i may have to do some spring swapping since i currently have no front swaybar, but given the characteristics, i dont feel i need one.
car will have to be in any unlimited category. it isnt very competitive, but i do it for fun, so im not too worried about it. If i did a miata engine, im not 100% sure what category it would be in
as for comming back to the states, not for a long while. the car is at my rents, and when i come home, ill be tracking it
Post by Deleted on Jul 29, 2012 13:32:59 GMT
The front and rear axel weights are done in the IVA test and as the car is pretty much 50/50 weight distribution side to side, it can be worked out there. Mine was around the 700 kg mark 400 front and 300 rear ish if that helps.
Post by shardy on Jul 29, 2012 18:44:23 GMT
That's really useful Alex, did they do left right differentials as well by any chance?
Post by Deleted on Jul 30, 2012 14:15:55 GMT
Nope, just front and back, with and without a driver. Think it's fairly evenly distributed left to right when driverless. With a 80-90 kilo driver and 80-90 kilo passenger I think it's almost exactly 25% weight per wheel. Circa 800-850 depending on the car weight, so about 200ish per corner
