Post by edwinwl on Feb 1, 2012 12:45:33 GMT
Like the lights also for sharp edges there are legislations.
I can not find the exact discribtion.
Suggestions?
Post by erik on Feb 2, 2012 10:04:34 GMT
I found some documention in this manual on page 28: mevowners.co.uk/Secure_Documents/RTR_Rocket_Build_Guide_May11.pdf40. IVA CAPS FRONT. HERE YOU WILL SEE ALL NUTS HAVE BEEN COVERED WITH EITHER CONVOLUTED TUBING OR PLASTIC NUT CAPS. ANY RADIUS OF LESS THAN 2.5MM WILL NEED COVERING IF THE EDGE CAN BE CONTACTED BY A 100MM DIAMETER BALL. On that page you will see rounded hexagon bolts as well. heads to the front, nuts facing to the rear. regards, Erik
Post by edwinwl on Feb 2, 2012 11:35:21 GMT
Hi Erik! Perhaps you are mixing up: SVA versus MSVA (standard car SVA versus Motor SVA)?
I am not sure yet...
Post by erik on Feb 2, 2012 12:52:48 GMT
Hehe, I'm getting cross eyed from reading pdf files by now. Too bad there isn't a Tr1ke manual available at this moment.
Post by roadtrackrace on Feb 2, 2012 14:03:57 GMT
There is a build guide for the tR1ke. It is a work in progress and will be updated in the next few weeks. It doesn't include the MSVA manual at the moment but I also have this.
The MSVA is passed very easily by the tR1ke as it is classed as open framed and the rules for contactable edges are extremely basic.
The lighting regs are also equally simple as you need no side indicators for example.
If you need to know more or would like a copy of the build guide, feel free to mail us on sales@roadtrackrace.com
RTR
