Post by leahy on Jan 12, 2012 13:02:13 GMT
Hi All
Firstly apologies if this has already been covered,
I am putting lights in my garage this weekend and then starting the strip of my mx5
I would really appreciate it if anyone could let me know of any odd size sockets or special tools that would be needed at a later stage
I have the standard stuff - rivet gun, sockets, torx axle stands, jacks, jigsaw, ramps etc but would hate to get to a certain point and realize i need to stop for something to be delivered or a 2 hr drive
Thanks
Post by stevieboy on Jan 12, 2012 13:31:26 GMT
Hi Leahy, welcome to the forum, don't forget the A frame and some cable ties with labels to note the electrics down, everything else is just straight forward with metric sockets. Just make sure you have a 29mm one plus an long bar for the axles. Steve
stubbers
Exocet Number 306
Post by stubbers on Jan 12, 2012 15:40:51 GMT
Post by mathew on Jan 12, 2012 16:24:41 GMT
Im just gona name some which havent been mentioned yet which ive found come in handy...
-spring compressors for the suspension -angle grinde + various attachments -vice pliers -allen keys -screw drivers -aviation snips -hammer, size depending on your level of patience! ;D
Post by leahy on Jan 13, 2012 11:42:40 GMT
Matthew, stubbers and stevie boy
Thanks for tips, there are a couple of items i dont have there so it was deff worthwhile asking. Will hopefully start the build blog at the weekend
h9
Junior
Purchased my Kit in 2011 and only just getting to start the build now in May 2015
Post by h9 on Jan 13, 2012 19:25:55 GMT
Tea and Biscuits :-)
Post by samuelt on Jan 15, 2012 17:33:47 GMT
Post by Stewart on Jan 16, 2012 9:41:05 GMT
Compressor and air gun if you can stretch to it. Blow torch to heat up those stubborn suspension bolts and bushes.
Post by sspogman on Jan 16, 2012 12:45:17 GMT
Rivnut installation tool - this is the updated version of the one that I have and it is an amazing piece of kit: www.memfast.co.uk/shop/Vprod2.asp?cat=2258004632Once you start using rivnuts, if you're anything like me, you won't know how you coped without them and will be looking at using them all of the time.
Post by leahy on Jan 16, 2012 14:40:38 GMT
Thanks all SSpogman - I am only familiar with the standard rivets that you grip and snap - how do these differ? genunine life changer? i was expecting sever hand cramp On another note - anyone in the essex area (I live in Epping/Ongar)
Post by Stewart on Jan 16, 2012 14:53:41 GMT
Rivnuts are threaded inserts. So you fit them in a similar way, but the crimping action secures the threaded insert in the hole giving you a proper threaded hole to fit a bolt into. Means the fixing your attaching isn't there for life
Post by samuelt on Jan 16, 2012 19:31:53 GMT
Rivnuts are fantastic, the tool i use looks more like a standard rivet hand tool. Search round on Ebay you may finds a good used one. i Managed to get a new one in a damaged case with more rivnuts than i will ever used for £30.
Post by adam1001 on Jan 16, 2012 20:17:18 GMT
One tool I've found really useful is a Clarke electric impact wrench from Machine Mart. Invaluable for undoing all the suspension bolts. You'll also definitely need a breaker bar - go for a decent one such as Halfords or it'll just bend as soon as you put a scaffold pole on it as I discovered.
Post by red5 on Jan 16, 2012 20:35:59 GMT
swear box - it will help you save money for new wheels
Post by stubbsy on Jan 16, 2012 20:37:52 GMT
If you are planning on dismantling the suspension and subframes for painting then you will need a ball joint splitter (I got a decent scissors type one off ebay for £8) and something to extract the bushes from all of the suspension arms (I found that a steel scaffold pole has just the right internal diameter so just cut a 10 cm length off your breaker bar extension, place it on the lip of the wishbone and then use a coach bolt and some large washers to pull the bushes out; simples!)
