Post by jamessid on Oct 23, 2011 10:25:50 GMT
When i removed the brake master cylinder from the MX5 (mk1 no abs)and removed the steel brake lines, i forgot to write down which was the front and which one is for the rear brake lines on the cylinder , i would appreciate if someone could tell me which way around i attach the front and rear brake lines
Post by lukiez on Oct 23, 2011 20:10:44 GMT
i assume you mean the brake "proportioning valve"? its marked on the side F for front and R for rear... i think
would need to check the workshop manual to be sure.
if you're talking about the master cylinder i would think logically that the double port on the end is for the fronts with the single port for the rear... i didn't seperate this to save confusion myself
