Post by Stiggy on Oct 11, 2011 8:48:18 GMT
Post by jonb2010 on Oct 11, 2011 11:04:16 GMT
They look smart. Have you got pic of them turned off and a link ?
Post by Stiggy on Oct 11, 2011 11:43:23 GMT
Post by nigel on Oct 11, 2011 19:44:00 GMT
You know I just can't believe that nobody’s commented !!!!! Re the first pictures of MEV’s new Lightweight - 300BHP per ton '750 series' Race Exocet note the missing MX5 sub-frames. nigel
Post by Deleted on Oct 12, 2011 14:48:05 GMT
can see that in the second pic, but clear for all to see in the first. looks great. take it theres a similar affair for the back too?
Whats the difference in cost for the frame? and of course weight saving?!
Post by h5ngs on Oct 12, 2011 21:43:56 GMT
Yes please more information on the light weight version with the tubular subframe design... before i buy the standard kit. Also is there a release on all of the changes on the light weight version, is it more power or just less weight to get 300bhp per tonne? please do tell and prices
Post by xvanwaart on Oct 17, 2011 20:39:33 GMT
Post by avantkiwi on Oct 18, 2011 19:11:00 GMT
Question on the Daytime lights. Does Mr IVA allow these to be on when the normal lights are switched on, or do they need to switch off when the main lights come on? I believe officially they are meant to switch off, but has anyone had experience at IVA with these?
Post by mathew on Oct 19, 2011 0:40:14 GMT
Guys, wouldnt it be easier to put the car through the IVA first then add the DRL's? That way its one less thing for Mr IVA to check.
Post by Deleted on Oct 19, 2011 13:16:39 GMT
I stuck mine through with DRL on the front - used them on the sidelight circuit as the headlights I had didnt have inbuilt sidelights. They came on and off with the switch the same as sidelights would, IVA man had no issues due to the fact a kitcar must have sidelights (nothing added to the IVA yet about DLRs as far as I know) and the LEDs are fine to be used as sidelights as long as theyre in the right position for sidelights. I doubt the position of the DRl on the lighweight would pass as sidelights though as they'll be more than 400mm from the edge of the car - assume theres sidelights elsewhere if its going to be road legal. If thats the case then maybe adding them after the IVA if you're looking at an unusual placement. bonus if using the sidelight switch is that the buzzer pings if you leave them turned on, and you dont have any extra wiring to do, placement of mine below after an IVA pass......
Post by Deleted on Oct 19, 2011 20:02:02 GMT
shown exactly where they were for the IVA. DRL are effectively sidelights, just white LED's apposed to standard tinged bulbs.
