Post by airforceone on Sept 15, 2011 18:26:33 GMT
Sounds Identical to the one I had. I am only using the Gearbox,driveshafts, rear calipers,engine/gearbox mounts and steering column I don't think you can actually use anything else. I used stripping the donor as a learning experience, selling the parts is a PITA as no-one seems interested in focus parts anymore.
I also have a new engine, a 2.0 litre one, but blelieve the ecu wont work with it, can someone confirm this.
Make sure you have lots of WD40 and good thick gloves, I lost count of the number of bolts that sheared and knuckles grazed. A car this old doesn't give it's componets away freely.
Ned
mattsmev
It's only Rocket science...
Post by mattsmev on Sept 20, 2011 16:17:17 GMT
Hi Ned. you can also use the rear number plate lights. they fit nicely and save a few quid.
From memory the bits that sold well for me were the little things like the gas struts off the boot lid, the areal and internal trim parts
Mattsmev
