Post by tikawawa on Sept 15, 2011 1:47:24 GMT
Could someone please give me a a hand and explain to me how the front suspension parts fit together? There are a couple of bearings, do they fit in the big aluminum block that is attached to the disc brakes. There are also some tapered bushings where do those go? And I ended up with one extra bushing, that does not seem to fit anywhere? Thanks alot!!
Post by Andy on Sept 15, 2011 4:40:44 GMT
Morning well where do u start if I was you I would get the bushes pressed in then fit the arms to the car then the shocks which will just give you the hubs to make up less parts to look at With the hubs not sure as not done them but sure Sum1 has & can help Hope this helps if not when I get home 2 nite I will post a photo Andy
Post by airforceone on Sept 15, 2011 6:29:10 GMT
There is a basic guide in the tech section on how it all goes together, I used it as a rough guide when I put mine together.
Ned
Post by nigel on Sept 15, 2011 9:43:18 GMT
As Ned has already stated their is in the technical section under suspension a downloadable pdf file covering the correct assy of the alloy upright written by RTR
Nigel
Post by tikawawa on Sept 27, 2011 23:58:16 GMT
Thanks guys, I got it done, it looks fine
