Post by kitcrazy on Aug 16, 2011 22:27:13 GMT
Have very nearly finished now i have finally got her started and the test is next tuesday so guess its about time to pop a couple of pictures up. So here she is.... Just the exhaust to alter and we are ready for the off, off to the test centre that is which seeing as it is 40 miles away is going to be an adventure in its own right. Fingers crossed
Post by kitcrazy on Aug 16, 2011 22:29:23 GMT
Just a thought, are collapsable steering bosses required???
Post by squelch on Aug 16, 2011 23:03:14 GMT
Good to hear its running what was it in the end ?
Post by Stiggy on Aug 17, 2011 9:26:13 GMT
Hi, you may need to prove that the steering assembly is ALL inc wheel from a type approved vehicle. The MX5 does have a collapsible boss. I noticed items like your top belt bolt needs a cap and not sure if you will see a left indicator from 45 degrees from the right of the car. They may be too far back. You need to trim the top edge of the side plastics inside the car to 2.5mm. There may be other items that need nut covers, edge caps etc. Always fix edge trim with PU as the inspector is entitles to check protective trim is fitted permanently. Hope this helps, regards Stuart. Looks nice BTW
cml
Newbie
Post by cml on Aug 17, 2011 11:53:17 GMT
Nice mirror, but why only on the left?
Post by fasteddie on Aug 17, 2011 17:58:23 GMT
Dear Mr Carson (kit), You will need a rear veiw mirror and definately one on the off side, this is obligatory, listen to our Master about edging and caps, put them on everything you can see, you can always remove after testing from parts of the fibre glass, especially check the under sides of the car for sharp protrusions, best wishes Ted
Post by tom on Aug 17, 2011 20:31:01 GMT
Looks very nice, the silver chassis looks great against the black
Post by kitcrazy on Aug 17, 2011 22:00:10 GMT
Thanks for all the advice
As i said, nearly there, hte other mirror and rear view mirror went on just after photo was taken and i have a pile of nut caps and edging to fit.
Regarding the steering wheel, as it is after market i guess that means it won't pass without the proper boss, i still have the original but has the airbag unit on it, can i fit this if the airbag is disconected?
The indicators stick out a fair way from the body so i think will be ok but will check, more concerned about the side repeators as the 5 degree viewable thing is very tight.
Squelch, it was a missing part from the immobilizer that was causing me all the grief, had to get a whole new ecu/immobilzer pack in the end...
Post by Andy Patey on Aug 18, 2011 17:40:53 GMT
spot on mate I like it you have done a good job Andy
Andy888
Exocet Builder
Post by Andy888 on Aug 20, 2011 20:15:29 GMT
Looking good. Nice to see some Exocets finally getting finished. I'm sure I've read about people sticking a cut up garden kneeling mat and stuck it on the middle of the wheel for iva.
Post by sspogman on Aug 20, 2011 21:02:22 GMT
She's looking great - love the silver chassis! :-)
