Wings
Jul 26, 2011 11:20:58 GMT
Post by motorhead on Jul 26, 2011 11:20:58 GMT
Hi All
Our wings have arrived today with a small packet of nuts and bolts etc. The large rear wing has several filled holes on the underside but I have no idea what I'm supposed to bolt where.
Could someone with a fitted rear wing post some pics for me to have a look at the fixings please?
Cheers all
M
Wings
Aug 17, 2011 14:37:53 GMT
Post by motorhead on Aug 17, 2011 14:37:53 GMT
Well, we decided rather than mess about drilling holes in the frame, we'd just weld it on instead. Job done and then off to JP Exhausts in macclesfield to replace the standard ford header and fit a packable exhaust, et voila!
Wings
Aug 17, 2011 19:56:03 GMT
Post by mwalley1 on Aug 17, 2011 19:56:03 GMT
Looks ace
Wings
Aug 18, 2011 9:09:35 GMT
Post by motorhead on Aug 18, 2011 9:09:35 GMT
Yeah, I think I prefer it without the engine shroud, and the exhaust is absolutely wicked. We got a 4-2-1 manifold from Burton Power, and the rest made up by JP Exhausts, their craftwork is unbelievable.
Wings
Aug 19, 2011 17:57:42 GMT
Post by a16xtm on Aug 19, 2011 17:57:42 GMT
do you use it on the road with no engine cover on?
does look alot better without it, but dont the police give you any hassle for it?
Wings
Aug 22, 2011 11:52:12 GMT
Post by motorhead on Aug 22, 2011 11:52:12 GMT
Well, no, it's illegal without a rear plate.
We took it off, so that JP had room to do the exhaust work for us, plus, we weren't sure at first whether the manifold would fit under the cover without modification. We did find the motor was quite a bit peppier with no back on though, so I think the cover is too close to the throttle body trumpets.
Wings
Sept 2, 2011 14:08:40 GMT
Post by motorhead on Sept 2, 2011 14:08:40 GMT
Well it's now finished! We have the front: and the rear: You might noticed we have replaced the damaged air filters (earlier pic), which caught on the bolts inside the cowling which now has a hole cut in it, as the trumpets were being starved of air. Everything we want (this year at least) has been done.
