Post by fasteddie on Jul 16, 2011 11:41:27 GMT
Post by 300tt on Jul 20, 2011 21:22:10 GMT
I didn't like how the front wing stays were installed either and noticed some issues on here. So, I drilled and tapped a 6mm x 1.00 "locater" hole to keep the bracket that mounts to the top ball joint from moving around. I've included a picture below. Also, I've been updating a very simple build log over at exocars.net. I thought since Kevin was doing his update on here I would do a build log on exocars.net to get some exposure for the Exocet over there since I believer we're the only two building one in the US? Our builds are so similar it's almost scarey. We've both disassembled and replaced/cleaned/painted almost all the parts along the way. The big difference is that mine will be white and his black:) Also, Kevin has done a MUCH better job of showing pictures of everything along the way. If anyone is interested, the link is: www.exocars.net/showthread.php?t=7494
