Post by kitcrazy on Jun 14, 2011 18:57:41 GMT
Hi
I've got a 1.8 engine and it would appear thati fail to check which was the inlet and which was the return nozzles on the injection rail when i was dismantling, tut tut. there is a small device on the bulkhead end of the rail that looks like it could be a one way valve but i'm not sure which way, anyone able to help
KC
Post by tlight on Jun 14, 2011 20:58:18 GMT
Hi,
I havent connected fuel yet,m but go to the technical section and you can access the Mazda Mx5 Mk1 & Mk2 Manuals there...
Tim
Post by Deleted on Jun 14, 2011 21:53:52 GMT
The valve is on the return end. The feed should come under and up at the front and the return is under at the back off this check valve. Alex
