Post by Tim Kerr on Jun 11, 2011 0:02:17 GMT
I had the rocket out for a short shake down tonight and just as I returned to the unit I list all gears.
Turns out the gear cable skipped of the gear lever (the one on the bottom of the lever that gets turned around).
I managed to reattach but it easily slips off so I guess it's shot.
So my options are new ford ib5 replacement cables or get some made up.
Was thinking of something with Rose joint ends or similar and was wondering if anyone has done this or knows were to go.
Replacement ford ones are the fastest and easies solution. But custom ones may be more reliable. Not sure what to do as i just want to get on the road!!!!
Any thoughts?
Tim
Post by juddyjuddster on Jun 11, 2011 7:35:35 GMT
I had much the same problem on mine but I think it's because the ib5 gearbox wants the ball 90' round. It was always twisted. So I cut the cable where it thins and made a sleeve with 4 grub screws. Now I can swivel the joint to the right angle and it has not popped off as yet. I will try to upload a photo. Cheers Ian
Post by juddyjuddster on Jun 11, 2011 7:45:06 GMT
Hi Tim here is a pic of my solution
Post by Tim Kerr on Jun 11, 2011 9:45:48 GMT
Thanks Ian
New cables being collected this morning from Ford and will see about modifying as you have done.
Nice solution.
Tim
Post by Scott on Jun 12, 2011 8:51:29 GMT
Am i missing something here?? we never had any issues with the gear cables in turning them round or anything,,, I think we connected them on and them when we got to the gearbox end the black rubber gromet was the wrong way round so i popped it out turned it round and refitted it and it pushed straight on to the gearbox never had any problems with it Scott
mightylad
.....Mighty MEV Rocket.....
Post by mightylad on Jun 12, 2011 9:34:43 GMT
Hi All (I think this should be a tech section thread??)
Anywho... I had a similar issue as described above (the ball cup was 90 deg out)... I just gripped the metal end of the cable and twisted the plastic ball cup the required amount with another pair of pliers... it twists really easily...
Simples!
Cheers, Ol
Post by juddyjuddster on Jun 12, 2011 21:05:07 GMT
That was a brave move.
Why did I not think of that?
Cheers Ian
