Post by squelch on Jun 2, 2011 19:12:48 GMT
as above a quick vid i did of how to remove the wiper stalk on a MX5 mk1 (i believe they did change the design at some point and this was off a 1995 model) as it says its easy to put back but it might be of use to someone
Andy888
Exocet Builder
Post by Andy888 on Jun 2, 2011 20:18:33 GMT
Interesting, we used a hacksaw!
Post by fasteddie on Jun 5, 2011 15:25:55 GMT
Wimps, we used a chainsaw. ;D
Post by sspogman on Jun 6, 2011 20:50:38 GMT
I took mine out initially by undoing the 2 screws, but then had a moment whereby I thought that I had read somewhere about removing it having an adverse effect on the clockspring. So, couple of days later, back in it went and out came the hacksaw instead...
Post by fasteddie on Jun 12, 2011 12:24:31 GMT
A cautionary warning, when putting the connector block back onto the assembly ensure you engage the fork on the indicator stalk with the indicator switch block pip. I did`nt and promptly broke it off. I still suggest the chainsaw method is still the easiest.
