Post by Deleted on Apr 29, 2011 8:32:56 GMT
Once again, Just wondered what size this would be? Is it Metric or imperial?
I know I used a lot of Metric last build, and although it fitted, it was not a snug fit and in the end was the wrong bolt. This could have resulted in a disaster on the road, so I want to make sure this time I fit the exact bolts :-)
Nick
Post by anglais on Apr 29, 2011 11:03:42 GMT
you will have to check with rtr, i used metric somthing like m14 i think
Post by Deleted on Apr 29, 2011 16:45:45 GMT
Cheers I will do, I don't like to pester too much :-)
vtR1k
I'm a trike lover...
Post by vtR1k on Apr 30, 2011 10:00:18 GMT
As far as I know, M10 fits for all suspension parts (uprights, wishbones, shocks). I used 12.9 strenght in stead of the normal 8.8. Don't want the suspension to come off
Post by Deleted on Apr 30, 2011 16:36:48 GMT
Yeah I will be going for 12.8, I did that on my MNR with exactly the same view, I want the very best of high tensile bolts insuring I don't end up in a tree or a Police Car
Post by edwinwl on May 1, 2011 7:40:37 GMT
I have used the following: 4x wishbones to frame are: 8x M12 x 65mm 2x Shocks to frame and wishbone: 4x M12 x 55mm 2x Bearing house: 6x M10 x 30mm and 2x M10 x 25mm 2x Wings: 4x M10 x 40mm 2x Lower ball joint: 4x M10 x 25mm 2x Willwood Brakes: 4x M10 x 70mm
I used standard bolts. 300 kg of car so 8.8 will do just fine.
Post by Deleted on May 1, 2011 9:47:03 GMT
I have used the following: 4x wishbones to frame are: 8x M12 x 65mm 2x Shocks to frame and wishbone: 4x M12 x 55mm 2x Bearing house: 3x M10 x 30mm and 1x M10 x 25mm 2 Wings: M4x 10 x 40mm 2x Lower ball joint: 4x M10 x 25mm 2x Willwood Brakes: 4x M10 x 70mm I used standard bolts. 300 kg of car so 8.8 will do just fine. Cheers for the bolt sizes you guys, It all helps, and I want to make a superb job this time.
vtR1k
Post by vtR1k on May 1, 2011 9:56:20 GMT
I have used the following: 4x wishbones to frame are: 8x M12 x 65mm 2x Shocks to frame and wishbone: 4x M12 x 55mm 2x Bearing house: 3x M10 x 30mm and 1x M10 x 25mm 2 Wings: M4x 10 x 40mm 2x Lower ball joint: 4x M10 x 25mm 2x Willwood Brakes: 4x M10 x 70mm I used standard bolts. 300 kg of car so 8.8 will do just fine. Probably will the standard bolts do fine. But I don't know how the dynamic force will be during riding. So that's why I took the stronger ones.
Post by edwinwl on May 1, 2011 17:35:16 GMT
Post by latemarch on May 2, 2011 20:43:57 GMT
I'm confused by the metric designations (stuck here in the US of A) I thought a M10 x 25 described the bolt. What is the 4 x in front stand for?
Post by Deleted on May 2, 2011 20:55:56 GMT
4x M10 you mean?
4 being the amount of bolts required ;D
