Post by andybaird on Aug 8, 2011 22:42:32 GMT
Post by nigel on Aug 9, 2011 8:12:50 GMT
Great photos and some good progress ;D Looking forward to seeing it finished. nigel
Post by andybaird on Aug 9, 2011 9:45:57 GMT
Hi All
Thanks for the comments Nigel. It's the support and comments on the forum helps to push you on in your build. Also the Newark Kit Car show gave me new enthusiasm to get it finished particularly the comments and encouragement from Matt and Will and all at team MEV.
Cheers Andy
Post by andybaird on Sept 4, 2011 20:55:36 GMT
Hi All I haven't updated for 4 or 5 weeks as I have been working away from home down in Crewe for the last 2 weeks. I have been home at the weekends so did get some work done on the kit. Some photo's of the progress. Exhaust Fitted Bracket for Lights All back lights fitted and working Seats & Roll bar Fitted
Post by andybaird on Sept 5, 2011 18:30:59 GMT
Hi All
Just to let you know the sonic moved under it's own power today all be it two feet forward & two feet back but still a big moment.
Will take it over to my test track (school Playground) at the weekend to give it a better run. I have asked for some help with the fuel filler cap in the Technical section if anyone can help it would be appreciated.
Cheers Andy
Post by airforceone on Sept 5, 2011 18:45:38 GMT
Looks good Andy.
Not long before your blasting round kirky, will keep an eye open for you.
Ned
Post by andybaird on Sept 5, 2011 19:01:39 GMT
Hi Ned Thanks for you comments but still a lot of work to do. I don't think it will be finish before Bishopbriggs shuts down in December. How is your build cumming on. Andy
Post by airforceone on Sept 5, 2011 19:44:52 GMT
It's only moving to Livingston, so not too far. I'm Still thinking of giving mine to RTR to put it thru IVA it may cost a couple of hundred quid more including a trailer but it should bve hassle free and hopefully get a new reg.
I'm still quite a bit of putting the engine in and wiring it up, I may be asking for your help at that point since youve sorted yours out.
Ned
Post by andybaird on Sept 5, 2011 19:54:32 GMT
Hi Ned
No problem if you need a hand just give me a shout.
Andy
Post by andybaird on Sept 6, 2011 17:02:09 GMT
Hi All
Still looking for a bit of help on how to fit the Fuel filler cap. I have asked the Question in the Technical Section but have had no luck. Hope Stuart or Nigel might help.
Cheers Andy
Post by s t o n i c on Sept 7, 2011 9:51:24 GMT
Andy
You aren’t tempted to put the tank up front then? I looked at putting the tank behing the passenger seat but decided it was too much work to make it look good and added weight to the back of the car. I also could not figure out a good way to connect the filler to the tank but part of the reason was I ran the brake pipes along the top part of the chassis rather than the lower part so was very little clearance for a filler hose. Hopefully someone that has none it will post some helpful pictures..
realtwin
Junior
Sonic 7 builder
Post by realtwin on Sept 7, 2011 15:54:32 GMT
Hi just had a look through your build..........looks great. One comment though I notice that you are using non hub centric wheel spacers. Personally I would not use them as you loose the spigot that the wheel locates on. This can lead to wheel wobble and puts more stress on the studs. I know these are light cars but I would spend the money on a better quality set. Regards Andrew
Post by andybaird on Sept 7, 2011 16:48:55 GMT
Hi Stonic
Thank for your thoughts on putting the tank up front. Not ruled it out but I would have to change the wiring & hoses.
Hi Andrew
I have ordered a set of hub centric spacers from e-bay last Friday so hope they will arrive this week.
Cheers Andy
Post by nigel on Sept 8, 2011 19:21:17 GMT
Hi All Still looking for a bit of help on how to fit the Fuel filler cap. I have asked the Question in the Technical Section but have had no luck. Hope Stuart or Nigel might help. Cheers Andy Sorry missed this one, pictures posted in Technical Section. nigel
Post by andybaird on Sept 8, 2011 20:45:26 GMT
Thanks Nigel
That the photo's that I was looking for. I think I will look at getting a filler cap like yours as the one I have has a bend in it which seems to take it away from the spout on the tank. If you don't mind can you tell me where you got it from.
Cheers Andy
