Post by wings on May 20, 2023 20:55:52 GMT
My name is wings. I have an MeV sonic 7 built on Ford Focus chassis. Registered in 2010 I would like communication with others who have one of these cars
Post by mawdo81 on May 22, 2023 8:41:14 GMT
Welcome! I have one registered in 2019. Its actually built on a custom chassis using the Ford Focus running gear...where are you?
Post by wings on May 31, 2023 19:33:52 GMT
Post by wings on May 31, 2023 19:50:51 GMT
Greetings I am in Great Yarmouth Norfolk. I bought two weeks ago MEV SONIC 7 registered in 2010. It is on mk1 ford focus chassis. Not sure as guy l bought from (2nd owner) gave me no paperwork about build. Reg#FJ60FXY Ford crated vortec black top engine 2.0. Originally 1.8 engine. Can you kindly let me know what Ford drive shafts you used please? Or any advice would be awesome 😎 I think either the driver side one is faulty, or differential. There is some vibration from takeoff. Where do even buy correct drive shafts, and or differential? I don’t even know where to get engine serviced? I am zero a mechanic, but some experience working on my cars. If you can assist me can l call you please so we on same page?
Post by mawdo81 on Jun 10, 2023 15:13:54 GMT
It's not a Ford Focus chassis, it's a custom chassis using the ford focus running gear. The drive shaft you need depends on the gearbox you're using. If you can't identify it then take some pictures and share them on here.
Any competent mechanic should be able to service it for you. If they need a reg number to get parts then use V278KDA for the engine, and rear brakes. For the gearbox and shafts use either that if its the MTX75 box or W506 GDT if its the ib5.
Post by wings on Apr 9, 2024 18:54:27 GMT
Post by wings on Apr 9, 2024 18:56:40 GMT
Post by wings on Apr 9, 2024 19:01:22 GMT
Would you kindly let me know where l can get a catalytic converter for my 2010 sonic 7 for fitting to an zetec 2.0 2004. Also front top passenger side ball joint? Car based on ford focus. Thanks in advance Wings
Post by wings on Apr 9, 2024 20:08:13 GMT
All is good now. Everything sorted. Car off to Ashford Kent for cat, wheel bearings and MOT. Getting it transported there. Train ride from GT Yarmouth to collect it when all completed. 175 miles to drive back home.
Post by wings on Apr 21, 2024 17:12:18 GMT
Post by wings on Apr 21, 2024 17:19:52 GMT
Is not Ford chassis, but MEV Custom one
Post by hutchey on Apr 22, 2024 7:24:34 GMT
All is good now. Everything sorted. Car off to Ashford Kent for cat, wheel bearings and MOT. Getting it transported there. Train ride from GT Yarmouth to collect it when all completed. 175 miles to drive back home. Hi, who did you use in Ashford for the work out of interest?
