Post by edwinwl on Feb 4, 2012 23:18:24 GMT
This weekend studied Dutch legislations. About placement of lights... This afternoon spend to make a better cover for wiring, support for swirltank, exup motor and licenceplate holder. Decided to place swirltank diagonal. Fuel lines have better direction.
Post by erik on Feb 5, 2012 10:04:12 GMT
Is the height of the plate based on the 5 degrees downwards visibility sketch on page55? Then you might reconsider to replace the swirl pod and mount the plate closer to the airbox (or make some fancy brackets on the airbox greets! Erik
Post by edwinwl on Feb 5, 2012 15:33:04 GMT
Nah, no relocation of my swirlpot. No brackets fixed to my airbox....
Post by edwinwl on Feb 6, 2012 18:18:40 GMT
Question: How to remove the Ford steering wheel?
Post by Deleted on Feb 6, 2012 18:53:10 GMT
I got the column in a vice, the wheel if it has an airbag will need un-bolting from the rear of the wheel first. then it should come away from the centre of the steering wheel. Once you have that removed you will see the nut on the spline, mine was a hexagonal shaft so a bit of tapping and it came off nice and easy. I decided to not use any of the original column.
I got a hub from eBay new for about £40 and it fitted straight on. I then bolted my wheel to it.
Post by edwinwl on Feb 7, 2012 20:58:32 GMT
Hi Venom, I borrowed a 5,5 mm plug to unscrew. Exactly as discribed the wheel got off. What hub you used?
Post by Deleted on Feb 7, 2012 23:09:42 GMT
Post by edwinwl on Feb 8, 2012 21:46:46 GMT
This evening cut and machined my steering wheel all the way back to a hub with functional steering lock. Pics will follow.
Post by edwinwl on Feb 9, 2012 19:20:48 GMT
Left over of my steering wheel after the abuse: Machined central hub in place: Machined central hub in my hand: I machined it with my drilling machine, axle grinder and file.
Post by edwinwl on Feb 9, 2012 19:28:32 GMT
Inspiration about doing this:
Post by Deleted on Feb 9, 2012 19:42:19 GMT
Thats excellent, it just shows what can be achieved with the right tools, I like how the boss is very slim instead of my big ass bulky one ;D
Post by edwinwl on Feb 9, 2012 19:53:49 GMT
And some Dutch muscles...... ;D
Post by erik on Feb 10, 2012 8:15:28 GMT
Great mod! I'm looking forward to your choice of steering wheel and finish of the steering column. It's a big help you posting these pics!
Post by edwinwl on Feb 11, 2012 23:19:54 GMT
Post by erik on Feb 11, 2012 23:45:40 GMT
Nice finisch on the steering(!!) but... are your fingers long enough to flip the turn signal lever?
Great progress. Wished I could catch up with you guys!
