Post by thomo1980 on Sept 20, 2020 11:51:42 GMT
Thought the alternator had gone down so got a new one fitted.. it turns out the alternator is fine.. checked under bonnet fuses all seem fine. Does anybody know what else I could try?
Thanks in advance
Post by kiwicanfly on Sept 20, 2020 18:34:58 GMT
Is there an in line load like a light on the dash? Without one the don't charge.
Does it pass through a master switch with dedicated alternator poles to the battery and if so is that good?
Both of the above happened to me!
Post by daydreamer on Sept 20, 2020 22:04:17 GMT
I had powder coated the alternator mounting bracket , breaking the earth route through the mounting bracket to the block. scraped the powder coat off the mating surfaces and then charging worked.
Post by rv8air on Sept 21, 2020 23:59:44 GMT
Here's quick test to see if battery is being charged by alternator: Before starting the car, check battery voltage, then start it up, and check voltage again. You should see a reading above that of the battery itself - 13.5Vdc or so. If you don't see the higher reading, the problem lies with the charging system, and not with the battery.
