Post by hammy3601 on Feb 14, 2019 10:21:23 GMT
Nice donor! Im just down the road from you and a few weeks til IVA, my thread is Surrey Exocet Build. Feel free to pop over, just send me a DM
Post by bewgy on Feb 14, 2019 13:13:03 GMT
Can I have the wheels and seats?
Post by p2tav on Feb 14, 2019 19:07:52 GMT
hi Russ
enjoy it don't let it take over your life and if you get stuck just ask a lot of good people with a lot of knowledge on here. i'm doing a mk2.5 there are a few differences with regards the build so if you need any advice drop me a message.
cheers Paul
Post by hammy3601 on Feb 14, 2019 20:50:42 GMT
Can I have the wheels and seats? I was being more polite and waiting for his DM as interested in the wheels lol :-)
russhowell
Post by russhowell on Feb 22, 2019 10:36:17 GMT
I'll be posting huge amount of items on eBay in the next few hours, but please feel free to contact me directly for a deal and i'll cancel the relevant eBay listing. bewgy, please PM me as I would like to offer the seats to you first as you expressed interest The wheels are not available
russhowell
Post by russhowell on Feb 22, 2019 10:47:48 GMT
So far the decomission has been straight forward. I am by no means a mechanic, but just looking for a bolt head and undoing it has so far worked.
A previous users forum helped with how to undo\disconnect some of the plugs so make sure you review them all. The Impact driver from Dewalt has become my best friend.. seriously takes the strain out of everything. Awesome.
I have even managed to remove in its entirety the boot and fuel cap release, in the hope I can sell it for a few pounds.
Thinsg I have found out so far: Doors are crazy heavy...I had no idea. Bonnet crazy light. Plugs will slide out easily if you pry tabs etc up completely.
So I have progressed further than this picture with most interior removed, literally just the dash, which is loose, but just taking a few more pics of cables!
Post by hammy3601 on Feb 22, 2019 13:30:49 GMT
Good work mate and good to chat to you today. 2019 Exocet comes out soon, then get your kit ordered. More than happy to help you and as discussed theres kit here you can borrow
russhowell
Post by russhowell on Feb 22, 2019 19:59:42 GMT
Bit of detail on the steering column removal. Couple of bolts on bracket just behind sterring wheel then 2 more down on bracket against bulkhead. Mine was then rusted into the pinch joint in engine bay. I removed bolt, put steering on full lock so I could see the joint and slid an old chisel in so it was up against the end of the column and wacked it.
russhowell
Post by russhowell on Feb 22, 2019 20:01:26 GMT
russhowell
Post by russhowell on Feb 22, 2019 20:06:46 GMT
russhowell
Post by russhowell on Feb 22, 2019 20:11:44 GMT
Now onto the pedal removal. Looks like accelerator cable ok to detach, but not sure how to detach brake from brake servo in engine bay and like wise the clutch rod that goes from pedal to clutch unit in bay....
and the pipes to the air con unit... but its all good fun
Post by jason82 on Feb 23, 2019 9:00:15 GMT
Now onto the pedal removal. Looks like accelerator cable ok to detach, but not sure how to detach brake from brake servo in engine bay and like wise the clutch rod that goes from pedal to clutch unit in bay.... and the pipes to the air con unit... but its all good fun With both the brake & master cylinder removal, there is a round bar which is connected to the pedals right at the top. So you will need to get on your back & look up at the pedals. The bar is connected to the pedals via a pin & circlip. Pop off the circlip & push out the pin, make sure that you put these back into the pedals for safe keeping. The brake master cylinder detatched from the servo with 2 nuts where they join together, then the servo has four nuts on the pedal side. Clutch master cylinder has two bolts keeping it to the bulk head. Take pictures of everything & label everything aswell. Even if you know where it goes now, you may not a few months down the line. There are also wires connected to the edge of the clutch & brake pedal mounts. Before you dis engage the braking system, undo the front wheel hub bolts as you will need to remove the rust tray to fit the wing mounts.
Post by jason82 on Feb 23, 2019 9:06:06 GMT
Oh, regarding the air con, officially you will need to get an air con expert in to safely dis charge the gas from the air con unit.
If a spanner accidently slips & starts undoing pipes then so be it lol. Just go careful as the gas may be under a bit of pressure. Just back off a connector to the air con pump or air dryer & that will do the trick. If your air con system was working fine, pop the full system up on eBay, someone may want to do a conversion.
Good effort so far, remember, your most important tool is your camera. Take pictures of everything, no matter how silly it may be as it may help you down the road.
russhowell
Post by russhowell on Feb 23, 2019 21:21:03 GMT
Brilliant, thanks Jason. I got the wings, lights and front off today, so just the pedals and associated gubbings, then there will be space to pull the harness. Got the ecu out and all other stuff unplugged Although I am liking Hammys idea about aftermarket loom. Will decide later, much later.
Dare I hope that the body will be off tomorrow....certainly by next weekend.
Will post pics tomorrow and of the subframe..looks scarily rusty....
