Post by Stiggy on Nov 19, 2018 22:20:49 GMT
Parts required from the MX5 donor include the front and rear sub frames, engine, gearbox, radiator, coolant pipes, calipers and discs/pads, flexy brake hoses (solid lines come with the kit), fuel tank complete with pump and sender, expansion bottle, all the suspension components, steering rack, steering column with cowling, steering wheel, light switch stalks, horn, side repeaters, brakes, transmission, exhaust system, wiring loom and engine management system, instrument binnacle, gear shift, pedal assembly, master cylinders, throttle cable, handbrake and cables, seats and runners, wheels and tyres (unless you choose grp seats or buy upgraded wheels), seat belts (unless you fit harness's), filler cap and pipes. There are also lots of useful nut and bolts and screws on the donor, and don't forget the boot trim, for the Exocet bonnet.
Exocet kit parts include a bespoke chassis, alloy floor, front bulkhead panels (these have folds but need trimming to suit) and front centre tunnel (rear centre tunnel is part of the chassis), PVC side panels and rear bulkhead, grp front and rear panels, 4 grp cycle wings, 4 steel wing stays, roll of brake pipe, p clips, roll of edge trim, bolts, washers and nuts, to secure chassis to sub frames, and rivets for the floor. Even self tap screws are included! You also receive touch up paint, radiator grille mesh, a bonnet sticker and a smile!
