Post by ian85 on Apr 16, 2019 21:52:26 GMT
Car is finished, IVA on the 26th! Fingers crossed!lol
Post by jleigh5 on Apr 17, 2019 8:56:41 GMT
Looks awesome! Is this the first G-Type going for IVA?
On the last photo, are the front indicators on the wings cause for concern? Can you see them from 45° the other way? I'm wondering what to do with mine, whether to use the supplied one (which imo look better) or get different ones for the IVA
Post by hammy3601 on May 4, 2019 14:53:20 GMT
Car is finished, IVA on the 26th! Fingers crossed!lol How did you get on mate?
Post by ian85 on May 5, 2019 12:29:03 GMT
Car is finished, IVA on the 26th! Fingers crossed!lol How did you get on mate? Passed last Friday, a couple of bits that had to be fixed on the day.
Post by hammy3601 on May 5, 2019 15:02:29 GMT
Good work! What did you need to sort on the day mate? Did you put anything on the lower 'dash area' on the passenger side for radius or werent they bothered?. The carbon area where you have that savage switch is what Im referring to mate
Post by ian85 on May 5, 2019 18:07:21 GMT
Good work! What did you need to sort on the day mate? Did you put anything on the lower 'dash area' on the passenger side for radius or werent they bothered?. The carbon area where you have that savage switch is what Im referring to mate I was ok with the bottom of the dash, as when I made the tray I bent it over a scaffold tube. So the bottom of the dash has a large rounded edge My headlamps caused the biggest trouble, they are the same as yours and didn't give a good flat pattern. Quick Google found they needed to be modified! He wasn't happy with my wing mirrors, because of the mounting arms had a edge less than 2.5mm,so had to cover them over. Other than these he was happy with the rest.
Post by hammy3601 on May 5, 2019 18:15:04 GMT
Was the headlight mod to put in 13 degrees of left kick up as Ive done with these lights on other builds mate?
Post by ian85 on May 5, 2019 19:42:20 GMT
Was the headlight mod to put in 13 degrees of left kick up as Ive done with these lights on other builds mate? Cheers Yep, that's the one But also had to fit better bulbs
Post by hammy3601 on May 6, 2019 6:31:17 GMT
Cool done the mod already too
Post by kev80 on Aug 22, 2019 11:46:53 GMT
Wheels are 16x8 and a et2 offset They look like they may be ok, the rolling size of the wheel isn't much different from the originals Hi Ian, what size tyres are you running on those 16x8 wheels please?
Post by ian85 on Aug 25, 2019 20:22:21 GMT
Hi,
I went for 225/40/16, but they are a very tight fit under the wheel arch. I also had to cut the wheel arch stays and lengthen them by about a inch.
At the time of building it, I was being told that handling and ride wouldn't be as good as 15 inch wheels with narrow tyres. I have to say that the ride is really good and so to is the handling, but what I would say is the Toyo T1-R tyres aren't up to much. You can find the limit of them very quickly!
Post by hutchey on Aug 26, 2019 13:52:28 GMT
Was the headlight mod to put in 13 degrees of left kick up as Ive done with these lights on other builds mate? Cheers What's the mod to do chaps?
Post by symo76 on Aug 31, 2019 15:43:08 GMT
Just thought I would share my progress of my g type since I collected my kit on the 12th July.
