Post by craigpusey on Aug 8, 2018 19:15:37 GMT
Hi all I'm currently going through my build and coming little things that I believe would be a massive help whilst you go through this process. According to the build guide you cut off the spacers on the rear of the brake and throttle pedal assembly and fit them the other side of the bulkhead, this will prevent the booster sealing to the bulkhead and to be honest seem a little wobbly. If I were to have some of these spacers made at a fair price would anyone be interested? I am also making weld in plates for mounting bonnet pins. PM me if interested.
Post by mikeeyboy on Aug 9, 2018 11:53:39 GMT
I welded plates into mine for bonnet pins, I can't say I have heard of many people having issues with mounting the bonnet?
I have seen a couple of builds and the primary issue I see with the pedal box spacers is that they all vary slightly on how they end up being fitted, I just use some stainless pipe and drilled a hole through it for the relevant lengths, 30 minute job and there is no movement at all.
Regards
Post by aterro on Aug 10, 2018 18:39:55 GMT
I’d be interested! Hi all I'm currently going through my build and coming little things that I believe would be a massive help whilst you go through this process. According to the build guide you cut off the spacers on the rear of the brake and throttle pedal assembly and fit them the other side of the bulkhead, this will prevent the booster sealing to the bulkhead and to be honest seem a little wobbly. If I were to have some of these spacers made at a fair price would anyone be interested? I am also making weld in plates for mounting bonnet pins. PM me if interested.
