Post by harryburnett on Jul 2, 2018 11:28:40 GMT
Hi all, Thankyou to everyone for you help over the months as the exocet is now on the road and legal! And very quick, couldn't be happier! However, been driving for a couple days now and there's an issue with the left indicators front and back. I have the led stop, tail and indicator lights of the back and the 2 indicators mounted to the front cycle wing. If I indicate right those work perfectly but if I indicate left I can hear the relay clicking very fast, the light barely shows up on the dash and shortly after the fuse will blow. Also when I switch on the hazards none of the indicators light up, it clicks slightly faster than usual and they light up on the dash but very faintly again. I'm pretty sure it's a short circuit somewhere but I've checked the wires that I've soldered to the new indicators on the left side but I just can't find anything that could be the culprit. If anyone can shed some light on this it would be greatly appreciated! Thanks Harry
Post by buildercg on Jul 9, 2018 11:35:58 GMT
Harry, check your grounds really carefully. I had this problem more than once and each time it was due to a bad/loose/missing ground. Good luck!
Post by harryburnett on Jul 9, 2018 12:27:18 GMT
Turns out it was just the indicator wire shorting out so all fixed now thankyou! Harry, check your grounds really carefully. I had this problem more than once and each time it was due to a bad/loose/missing ground. Good luck!
