Andy888
Exocet Builder
Post by Andy888 on Mar 28, 2011 23:02:19 GMT
Really impressive build Kevin. Love seeing your updates.
Post by Kevin Patrick on Apr 4, 2011 22:35:22 GMT
Finished up a few more engine-related items. Installed a new thermostat Heater Bypass Reinstalled valve cover (went back and forth on painting/polishing/powdercoating it… think I'll wait til later)
Post by Kevin Patrick on Apr 4, 2011 22:36:15 GMT
Finished installing the front brakes and fabricating aluminum brackets for the front stainless steel brakes. Installed the front brakes Ran the new stainless steel lines Bent some aluminum for the front brake line bracket Used a drill press and step drill bit to drill out the hole for the brake line mount Painted the brackets Riveted the brackets to the front subframe I also rotated the rear brake distribution box per the April 2011 version of the Exocet Build Manual. My stock line was in good condition so I retained it and installed p-clips with M4 rivnuts in the holes where the original plastic clips were located on the rear subframe.
Post by Kevin Patrick on Apr 4, 2011 22:37:48 GMT
Post by Kevin Patrick on Apr 4, 2011 22:49:14 GMT
Suspension is on! Front Rear
Post by Kevin Patrick on Apr 4, 2011 22:49:47 GMT
Time for spacers, wheels and tires. She is really starting to look like a car now... 32mm Spacers installed Then the first wheel Then on to the rest of the wheels Front Left Corner Front Right Corner Rear Left Corner Rear Right Corner
Post by alan87 on Apr 5, 2011 5:37:19 GMT
Wow! Great stuff as usual Kevin!
Andy888
Exocet Builder
Post by Andy888 on Apr 5, 2011 9:37:05 GMT
This is a superb build. Am sure everyone on here building one of these is grateful for your detail and pics.
Post by Deleted on Apr 5, 2011 11:15:03 GMT
This looks fansatic Kevin, Love the detail and level of quality going into it. makes mine look shabby now!!
Post by bouns on Apr 5, 2011 16:26:21 GMT
superb build kevin!and some very helpful photos.
Post by Kevin Patrick on Apr 11, 2011 18:01:47 GMT
Made a little more progress on the Engine/PPF. New NGK spark plug wires arrived and installed New PCV valve installed Installed three new rivnuts and p-clips in the PPF to hold the wiring harness. (I broke a few of the plastic clips during disassembly.) Also installed the speedo cable. Ran and hooked up the rest of the harness that goes from the battery to the starter/alternator
Post by Kevin Patrick on Apr 11, 2011 18:02:21 GMT
Post by Kevin Patrick on Apr 11, 2011 18:03:44 GMT
Post by Kevin Patrick on Apr 11, 2011 18:06:31 GMT
Warmer weather made it a good time for cleaning and painting of some additional donor parts. Clutch pedal assembly, brake booster/master cylinder assembly, and steering column were finished over the weekend. Need to finish up the brake/accelerator pedal assembly next. Used some of the Rust-oleum Hammered finish that can be applied directly to rusted metal - worked well for this application as there were plenty of surface imperfections. www.rustoleum.com/CBGProduct.asp?pid=159Brake booster/master cylinder before and after Clutch pedal assembly
Post by Kevin Patrick on Apr 13, 2011 1:55:27 GMT
The replacement mandrel for the rivnut tool arrived today and I finished running the fuel and brake lines through the tunnel. I used 3/16" brake lines and 5/16" Goodyear fuel injection hose www.goodyearep.com/productsdetail.aspx?id=5144.
