Post by sidpotters on May 21, 2018 15:09:15 GMT
Afternoon,
After advice ref the above. Getting mine ready for IVA and have bought a surround and light to go over it to illuminated the rear plate. Do we need the plate surround or can the plate, once registered, go straight onto the body? Also, the light, if above the number plate, being flat backed, does not follow the curve of the body - how best to address this? Can you get a curved back light?
I notice on Cheshire Build (love those wing mirrors) that he appears to have two little studs to the left and right of the plate, assume these are lights.
Any feedback, as usual, gratefully received.
Sidpotters
Post by Stiggy on May 21, 2018 18:13:03 GMT
you do need to show number plate space provision, easiest way is to show a dummy plate or a alloy plate to mount the real thing. They often ask for 2 lights like all cars have, not one. Bolts with lights are usually accepted.
Post by tojeiro on May 22, 2018 14:55:43 GMT
Looking at same issue.
I was just going to make a number plate backing plate out of aluminium with a folded over angle at the top and stick on an white LED strip on the inside that would then shine on the plate. Bit of edging trim to avoid sharp edges.
Interested to see what your final solution is might save me time and effort.
Post by brettlawrence on May 22, 2018 16:38:55 GMT
I got away with a single light mounted above the number plate with an aluminium shroud.
Post by Stiggy on May 22, 2018 19:15:36 GMT
I got away with a single light mounted above the number plate with an aluminium shroud. you may have been lucky, they expect the lights to illuminate the whole plate not just the middle.
Post by tojeiro on May 23, 2018 0:14:15 GMT
Can the numberplate light face upwards or does it have to mounted at the top or sides, couldn’t see any restriction in the IVA manual.
Post by Stiggy on May 23, 2018 8:04:23 GMT
The lights can be above, at the sides or below as long as they illuminate the whole plate.
Post by tojeiro on May 23, 2018 9:29:31 GMT
Cheers Stuart, sounds like a good lunch-hour project.
