Post by garman on Aug 13, 2018 13:07:39 GMT
This weekend I tackled the differential and PPF. I picked up a Torsen locally so I needed to get it cleaned up and painted. Also replaced the bushings with some new poly bushings. Bushing barbecue Painted diff Back together with the painted PPF The old, sad open diff in the background. Next weekend I'll be putting in the FM stage II clutch and flywheel and mating to the transmission. Things should pick up speed after that until I get to the wiring.
Post by garman on Aug 13, 2018 15:24:30 GMT
Overdue update: FINALLY got the engine together. The cheap adjustable timing gears are totally jacked up. The cam position triggers didn't come close to matching the OEM gears. I measured everything on a CMM at work and made the adjustments to make them work. This picture was taken without any timing done so I know the cams are in the wrong position. I just wanted to see what everything would look like assembled. Also, the valve cover is getting powder coated but I'm waiting to send everything out at once, calipers, brackets, etc. Is anyone else running adjustable cam gears? Any input?
Post by garman on Aug 21, 2018 13:03:06 GMT
Post by garman on Aug 21, 2018 13:06:36 GMT
Helpful tip on the rivnut installation:
I had the rivnuts and the installation tool stored inside the house where it's nice and cool. When I started installing the rivnuts they took quite a bit of force to get them to set completely. I took a break and went inside to cool off because it was 95° out. When I came back out the rivnuts had been left out in the sun and were too hot to handle with my bare hands. This was a fortunate accident. When I installed the hot rivnuts they went in like butter. Hardly any force to get them to set. So, rivnuts that are heated are waaaaaay easier to install than cold ones. Makes sense but I would have never thought to do it. Probably works with rivets too.
Post by garman on Sept 4, 2018 13:33:04 GMT
Started the Holiday weekend by assembling the rear end.
Post by garman on Sept 4, 2018 13:34:42 GMT
Next was installing the FM Stage 2 clutch and lightweight flywheel.
Post by garman on Sept 4, 2018 13:38:43 GMT
Now feeling super motivated, I mated the transmission and motor and decided to assemble the rollerskate Sunday night.
Post by garman on Sept 4, 2018 13:47:58 GMT
Everything actually went together relatively smoothly. I didn't have to make any adjustments to the PPF mounts so I'm hoping I have the alignment right. I'm pretty stoked to get this far. I'm waiting to get my bulkhead panels back from powdercoating. Once I get those I can put the frame onto the PPF. The brakes, valve cover, water pump pulley and coolant lines are going to powdercoat this week. I'm going to be in China for a week starting on Friday so everything is on hold for a while.
Post by garman on Sept 24, 2018 15:13:24 GMT
I've reached a pretty big milestone in the Exocet build this weekend. Finally got the frame mated to the chassis. Really starting to look like a car now. Strapped up: Having the frame this high up in the air turned the pucker factor up to 10.
Post by garman on Sept 24, 2018 15:15:40 GMT
Post by garman on Sept 24, 2018 15:18:17 GMT
There is plenty yet to do but I'm happy to have gotten this far without too much trouble. I've got Sparco Sprints on order and they should arrive next week. Brakes are powder coated and need installed. Of course, the electrical, fuel and brake lines are going to be fun. I'm thinking about a month out and I'll be ready to turn the key.
blacksweeper
Junior
Currently building a top level Exocet
Post by blacksweeper on Sept 25, 2018 0:34:10 GMT
Gary,
Jerry in Vero Beach, your build looks great, nice work. I completed my skateboard and mated the chassis up Friday 9/21. We are at about the same point in our builds. I look forward to running together at some trackdays and or Autocross events. Keep up the good work.
Post by garman on Sept 25, 2018 1:10:18 GMT
Hey Jerry!
Glad to hear you are making progress. It's been slow going for me but I'm trying to get everything right the first time. I'd love to take a road trip someday and meet up!
Post by jwagner on Sept 25, 2018 18:32:10 GMT
A very nice, clean build - nice work. Thanks for the pics.
Post by garman on Sept 29, 2018 14:54:48 GMT
A very nice, clean build - nice work. Thanks for the pics. Thanks! So much left to do. I'm trying to document as much as possible so I can look back on it someday and say "yeah I did that" and help anybody else in the process of building one of these things. I have to say I've probably taken more from this forum than I've given, though.
