Post by sidpotters on Feb 3, 2018 12:16:15 GMT
Afternoon, Could do with some advise ref fuel filler cap and the IVA. My understanding is the filler cap can't be in the boot so needs to be external,and tethered. Thinking of putting a 2" classic type on, this has the snap clamp type clip to secure , would this pass the IVA? Are there any conditions it has to meet ref fitting flush, upstanding a few inches?
Post by Stiggy on Feb 4, 2018 9:55:09 GMT
If the boot is not a boot, in other words has not been boxed in to create a storage space then the cap can be under the boot lid. If above it needs to be radiused all around to a minimum of 2.5mm, but a hinge type cap is classed as tethered. Tank must be able to breath, some classic type caps do not have a vent.
Post by sidpotters on Feb 4, 2018 10:55:32 GMT
Thanks.
Post by ancsportscars on Feb 4, 2018 11:04:30 GMT
Also, it must not protrude more than 50mm from the external surface (Section 16 of IVA manual 'External Projections'- Reqd standard 19.)
Post by sidpotters on Feb 21, 2018 19:46:50 GMT
Anyone recommenda a supplier for the fuel cap that does comply? Want a tradition aston looking unit
Post by sidpotters on Feb 21, 2018 19:52:16 GMT
Something like picture in last post
Post by ancsportscars on Feb 21, 2018 20:16:22 GMT
Have a look at Steve's 'Norfolk Build' thread on next page. He has photos of his IVA test (page 4) with what looks like an Aston style cap fitted and he had a first-time pass. So could be worth sending him a PM to see where he got it from? (as most would fail on height and radiused edges.)
Post by stevednorris on Feb 22, 2018 8:13:46 GMT
Post by casesensitive on Feb 22, 2018 17:59:15 GMT
Handsome, certainly, but £126...
Post by sidpotters on Feb 23, 2018 15:56:36 GMT
Thanks for the feedback, ordered, should be here this afternoon
Post by R2S on Aug 2, 2021 8:06:12 GMT
How did you vent? I was going to use original MX5 filler but can't get clearance between body and tank so need another solution I dont have a boot lid (I have one piece body) so looking to place filler in centre of rear deck.
Post by tojeiro on Aug 4, 2021 18:30:21 GMT
CBS do a fuel grade plastic pipe fitting with ‘t’
I used this with the same cap and just ran a separate rubber fuel pipe vent line from tank to the ‘t’ just below the filler cap.
Post by R2S on Aug 4, 2021 20:58:37 GMT
Had a look and can't see the pipe with T you refer to spoke to cbs and they said they didnt have anything matching my description. Filler ordered and will come up with a solution for breather.
