Post by ian85 on Mar 16, 2019 17:50:58 GMT
At what point is it doing this? Start up from cold or after it has warmed up?
Post by hammy3601 on Mar 16, 2019 20:40:16 GMT
struggling, car has developed a misfire/hunting, gents my car engine has developed a miss/hunting problem revs keep dropping on tick over and sometime misses when held on constant revs. I have changed MAF and coil packs but still same it smells very rich so don't suspect fuel pressure any ideas please ? cheers paul What did you end up doing with the vac lines as in your previous post mate? If you've changed that and this started happening that would be my first port of call
Post by p2tav on Mar 18, 2019 19:03:00 GMT
struggling, car has developed a misfire/hunting, gents my car engine has developed a miss/hunting problem revs keep dropping on tick over and sometime misses when held on constant revs. I have changed MAF and coil packs but still same it smells very rich so don't suspect fuel pressure any ideas please ? cheers paul What did you end up doing with the vac lines as in your previous post mate? If you've changed that and this started happening that would be my first port of call hi hammy / ian85 ive put the vac lines back as they should be and still having issues its like the cold start is sticking in open position it is doing it when cold and hot. i wonder if it just needs a run as it cant be good just starting it up time after time ? thinking of having it Terra cleaned to get rid of all the crap as they must get carboned up in the garage? cheers paul
Post by p2tav on Mar 20, 2019 13:33:17 GMT
Post by p2tav on Mar 23, 2019 16:34:04 GMT
Gents,
can someone send me a completed IVA form for me to see if ive got it right please? you can email it me I will send my email via message if your able to.
regards paul
Post by hammy3601 on Mar 26, 2019 19:16:58 GMT
Gents, can someone send me a completed IVA form for me to see if ive got it right please? you can email it me I will send my email via message if your able to. regards paul Not sure many will do that mate as the forms contain private personal information. Im happy to help if you send me your forms with all personal info removed. (Yes I work in Cyber/Information security)
Post by p2tav on Mar 26, 2019 23:14:40 GMT
Gents, can someone send me a completed IVA form for me to see if ive got it right please? you can email it me I will send my email via message if your able to. regards paul Not sure many will do that mate as the forms contain private personal information. Im happy to help if you send me your forms with all personal info removed. (Yes I work in Cyber/Information security) hi buddy, i was not expecting anyone to send me their forms with personal details but i get you, i think i have them sorted now i'm sure if they are wrong they will send them back. fingers crossed all is good i'm going to wait for a few weeks as i,m struggling with trying to figure out how to mount the headlights so the front wheels don't hit them when turning and going over potholes. i,m using the twin setup and i'm trying to come up with a way of mounting them so IVA will be happy too cheers Paul
Post by Stiggy on Mar 27, 2019 10:55:12 GMT
Post by p2tav on Mar 28, 2019 14:47:12 GMT
thanks Stuart
Post by p2tav on Apr 12, 2019 19:41:59 GMT
Post by p2tav on Apr 18, 2019 12:59:33 GMT
Post by bigdave1 on Apr 18, 2019 15:05:17 GMT
Cracking progress mate. Have you managed to sort out the engine tick over issue ? May I suggest a cold air sensor? That could cause issues as its fed by the ECU. What are your grounds like ? I suppose if all else fails, you can drop a computer on it, or is it the led system on your car ?
Post by Stiggy on Apr 18, 2019 15:06:21 GMT
Looking great Paul, very well done. You will need to change the mirrors as you are only allowed 1 indicator per side, they also look quite low so you need to be sure that rear visibility angles are OK. You need a marker post setting up as per the IVA manual to check this properly. Rear reflectors will need to point rearwards as it looks like yours are pointing sideways. Obviously you need front side lights as these are not built in to the projector headlights. Check also that the radius edges of your wishbones are 2.5 mm or more, if not add a glued on trim, knock on may not be acceptable if it comes off easy. The bone edges are tapered so it is difficult to secure knock on trim without using a bead of PU and gaffer tape until cured. Good luck with the test.
Post by p2tav on Apr 18, 2019 16:44:15 GMT
Looking great Paul, very well done. You will need to change the mirrors as you are only allowed 1 indicator per side, they also look quite low so you need to be sure that rear visibility angles are OK. You need a marker post setting up as per the IVA manual to check this properly. Rear reflectors will need to point rearwards as it looks like yours are pointing sideways. Obviously you need front side lights as these are not built in to the projector headlights. Check also that the radius edges of your wishbones are 2.5 mm or more, if not add a glued on trim, knock on may not be acceptable if it comes off easy. The bone edges are tapered so it is difficult to secure knock on trim without using a bead of PU and gaffer tape until cured. Good luck with the test. hi Stuart thanks for the advice, I have disconnected mirrors and im going to tape the lenses up, I will do the test for visibility cheers:) ive already moved the rear reflectors to point in the correct direction. all the wishbones are covered in trim and glued on its just silver so hard to see in pictures. I have drilled a hole for a single LED that you supplied to fit in the middle of each light set so should be ok fingers crossed. cant wait for you to see it hope it does MEV proud, regards, Paul
Post by p2tav on Apr 18, 2019 17:18:57 GMT
quick question,
when I connect near side headlights they work fine dipped and main beam but when I connect off side both dipped and main beam come on ? any ideas please ive tested the wires and im getting the correct voltage and on the right connections ?
anyone else had same issue
