Post by jason82 on Feb 10, 2019 21:21:07 GMT
That looks very similar to the Mercedes 190E radiator that I used in my Haynes Roadster (manual radiator, not automatic). Try lowering your radiator as low as it will go so that the bottom of the radiator brackets rest on the lower beam, that's how I have mine, it is really tight.
Failing that, why don't you do what the American boys & Exomotive do, & put it on the engine side of the front frame ?
Post by jason82 on Feb 10, 2019 21:32:45 GMT
Sorry, just looked back through your thread to see how it was mounted. My thinking is cut the lower edge of the bonnet where it touches the base of the radiator ( or close to it), then change your radiator brackets slightly to get it to sit lower in the front frame. Mercedes rad I mention previously is very compact & comes from a 2l, so plenty of cooling, just double check the specs. They can be found on eBay, type in Mercedes 190E manual radiator, then look for the Nissen listings, they are on there.
My first step would be to fabricate different rad brackets & get it sat down in the front frame a bit more.
I presume that you are using the mk1 radiator ? I know that your car is a 2.5 ? The rad brackets only work with a mk1 radiator. I hope that this helps you !
Post by p2tav on Feb 10, 2019 21:49:19 GMT
Sorry, just looked back through your thread to see how it was mounted. My thinking is cut the lower edge of the bonnet where it touches the base of the radiator ( or close to it), then change your radiator brackets slightly to get it to sit lower in the front frame. Mercedes rad I mention previously is very compact & comes from a 2l, so plenty of cooling, just double check the specs. They can be found on eBay, type in Mercedes 190E manual radiator, then look for the Nissen listings, they are on there. My first step would be to fabricate different rad brackets & get it sat down in the front frame a bit more. I presume that you are using the mk1 radiator ? I know that your car is a 2.5 ? The rad brackets only work with a mk1 radiator. I hope that this helps you ! hi Jason, my rad fan is sat on bottom brace so can not lower any more, it wont go back any further as the fan cowling is touching. as for the version of Exocet that it fits behind the frame they are different at the front and wider like the mk1. I can get bonnet on but not back far enough and I wont let it beat me. I cant live with it if its not right lol I will get it back enough just might need to fit smaller rad. cheers
Post by jason82 on Feb 11, 2019 7:53:36 GMT
Good luck mate, sounds like a really frustrating time.
Post by ian85 on Feb 11, 2019 7:57:52 GMT
I went with a £20 eBay fan kit and that aloud me to get the rad back a little more. I also ended up fitting the rad 10 degree's in at the bottom, which gave me better clearance.
Post by hammy3601 on Feb 11, 2019 11:11:27 GMT
I also ended up fitting the rad 10 degree's in at the bottom, which gave me better clearance. I did the same and now fits perfectly
Post by p2tav on Feb 11, 2019 20:28:45 GMT
Well gents, I have spent all day trying to get my bonnet to fit, in the end I removed rad and it still would not go back. I have had my head in my hands all day when I finally realised my uprights stick out and are stopping the bonnet from pushing back the left one has a big blob of weld on it to make it even harder, they are proud of the top rails so are hitting at both sides of the bonnet. I have decided to cut the bonnet as I don't want to destroy the powder coating after several hrs of cutting (a bit at a time) if you get me I have got it to fit as I wanted it to. I have ordered a smaller rad as now bonnet is in the correct place there is no chance it will fit no matter how I positioned it. I just hope new rad fits as no turning back now I will post some pics soon to show you how i'm getting on. cheers
Post by jason82 on Feb 11, 2019 20:59:22 GMT
Good luck Paul, have you spoken to MEV about this ? They may have an idea how to get the bonnet to clear the radiator.
Post by p2tav on Feb 12, 2019 9:39:13 GMT
Post by jason82 on Feb 12, 2019 10:08:13 GMT
Looks good, tell you what, that looks like an old Peugeot 205 / citroen AX radiator. If it works you may start a new trend on here lol.
Post by p2tav on Feb 12, 2019 11:25:22 GMT
Post by p2tav on Feb 28, 2019 18:10:05 GMT
well gents a good day at last I have mocked up the new radiator brackets and tested the bonnet for fitment and its much better with the smaller radiator. I had a moment when waiting for fan to kick in but eventually it did thank god, the bonnet is now no where near the rad so I feel much better if an issue with overheating should occur.
Post by p2tav on Mar 1, 2019 10:30:54 GMT
question gents,
on the throttle body there is a vacuum line sticking out of the side what are people doing with it ? if you block it seems to run richer is that the case ? is it better to out pipe on it direct it out of the way and vent it ?
cheers Paul
Post by hammy3601 on Mar 12, 2019 15:23:24 GMT
question gents, on the throttle body there is a vacuum line sticking out of the side what are people doing with it ? if you block it seems to run richer is that the case ? is it better to out pipe on it direct it out of the way and vent it ? cheers Paul Send me a pic mate and Ill send one of what Skuzzle did on my car
Post by p2tav on Mar 16, 2019 9:39:21 GMT
struggling,
car has developed a misfire/hunting,
gents my car engine has developed a miss/hunting problem revs keep dropping on tick over and sometime misses when held on constant revs. I have changed MAF and coil packs but still same it smells very rich so don't suspect fuel pressure any ideas please ?
cheers
paul
