Post by dave on Jul 24, 2017 13:01:09 GMT
So I'm ready to send off the chassis for powdercoat but want to clean and smooth the welds, should I be using a grinding disc or something less abrasive; Thanks Dave
Post by jgilbert on Jul 24, 2017 17:31:05 GMT
Welds will be structural so care must be taken not to remove to much metal. I personally wouldn't use a solid disc maybe a sanding disc on a flexible pad or ideally small grinding burrs to gently radius the weld.
Post by buildercg on Jul 24, 2017 18:16:46 GMT
Agreed. Maybe some light sanding but I wouldn't remove very much material on any of the welds holding any of the tubes together.
Post by kiwicanfly on Jul 24, 2017 19:04:37 GMT
Once you start cleaning up welds it is hard to stop. Assuming we are discussing a neat factory or professional weld, they actually look worse partially cleaned up than left untouched. More importantly, as said above, you can do a lot of harm in terms of structural integraty. Some authorities phohibit this as well. So my advice is to learn to love your welds
Post by dave on Jul 24, 2017 19:39:23 GMT
Thanks for the advice guys, think my ocd maybe creeping back in. Think I'll leave it as is. Dave
