olberj
SC Rocketeer
Post by olberj on Jul 21, 2017 16:53:16 GMT
Something we noticed when setting up the alignment on my rocket, the wishbone bushings don't move freely.
The clamp of the nut and bolt mean that it binds slightly.
What does everyone else do?
Leave them ever so slightly slack?
Fit longer tubes inside the bushes?
It's not a deal breaker but I'd like to get it right.
Post by gwnwar on Jul 22, 2017 4:44:37 GMT
You need the bushings inside the rubber or poly.. You could pull the tube and shave a mm off the rubber or poly. Or if you can find a small washer to fit between the tube and mount and not touch the bush.. Might have to relieve the bush for washer to fit..
olberj
SC Rocketeer
Post by olberj on Jul 22, 2017 6:31:39 GMT
Cheers. Right sized washers shouldn't be too much of a struggle. I'll measure up and see what i can find.
