Handbrake
Jun 20, 2017 12:54:00 GMT
via mobile
Post by shelleyx191 on Jun 20, 2017 12:54:00 GMT
Hey everyone Not sure about cable routing or location of lever if anyone has any pics would be very helpful Cheers
Handbrake
Jun 20, 2017 16:01:14 GMT
via mobile
Post by tojeiro on Jun 20, 2017 16:01:14 GMT
Post by brettlawrence on Jun 20, 2017 22:53:53 GMT
I did much the same as tojeiro except that I mounted handbrake cable supports to the back of the MEV chassis instead of the rear subframe. I used a vertical brace that coupled to the original MX5 cable slider instead of a wheel riser. Otherwise it's much the same. Can provide pics if required.
Post by shelleyx191 on Jun 21, 2017 8:08:42 GMT
Hi brett if you have some of your pics be great to see them....the more tne merrier....cheers
Post by shelleyx191 on Jun 21, 2017 8:18:13 GMT
Hi tojerro great pictures thanks very much....Rob
Post by R2S on Jun 21, 2017 10:10:08 GMT
Page 15 my build shows angle brackets I made which are held in place by the bolts which secure petrol tank. The standard MX5 cable brackets are then used, these locations turned out to be perfect for the location of the brackets and provide a nice smooth curve avoiding any internal snagging of cable.
Post by brettlawrence on Jun 21, 2017 16:33:16 GMT
Drivers side, showing underside of fuel tank and small welded on bracket with p-clip around handbrake cable. Fuel tank also earthed to this. Passenger side, similar small welded bracket and p-clip. Routing of cables into cockpit. Lever mechanism. Small tapped aluminium cylinder with a recess to capture the clip from the original cable slider. Cylinder bolted in from below. Thin ally sheet cover bolted to rivnuts.
