Post by martinw on Jul 14, 2017 14:34:36 GMT
Seems the bracket for the extra idler has moved out of line; turns out that one of the studs into the engine block has sheared (b*gger!) and will need removing before I'm mobile again. So, having accumulated necessary tools and gadgets (thingy to drill at 90 degrees, eeziouts, 10mm HT setscrews....) I set about it today. Sheared stud was in THE most awkward position between the block and the rear bulkhead, so drilling a hole centrally in it with a thingy to allow you to drill at 90 degrees really wasn't that easy. Anyway, perseverance paid off. Next came the eeziout......not the most appropriate name IMHO. Again, due to the limited access (and not helped by the hole being not quite vertical in the stud) I couldn't get a tommy bar on it. That meant a mole wrench to grip the top, and painfully slow extraction a quarter turn at a time. Good new is.....all safely extracted, bracket now secured with new HT setscews, drive belt back on (and content to stay on when engine is running, which is a huge bonus  ). Now got to clean it (and of course a quick test run.....would be rude not to!!) See you all tomorrow. Martin
Post by maz27 on Jul 14, 2017 15:45:39 GMT
Kate is alive now time for bodywork and tyes
Post by p5curly on Jul 14, 2017 16:59:44 GMT
Just got to clear the rubble from in front of yellow Mevsters shed as we are doing some landscaping work at the same time
Post by nigel on Jul 14, 2017 17:04:05 GMT
Curborough is open for business. Atomic, Rocket & Exocets so far 😁. Anyone else camping or car sleeping ? Nigel upload your pictures
Post by nigel on Jul 14, 2017 18:55:02 GMT
Guy sets up the autotest ☺
Post by p5curly on Jul 14, 2017 18:58:13 GMT
Post by nigel on Jul 14, 2017 19:01:37 GMT
More attendees ☺
Post by maz27 on Jul 14, 2017 21:25:01 GMT
Wish we was still putting her back together
Post by maz27 on Jul 15, 2017 6:39:15 GMT
Why are the gates locked
Post by bl4ck4dd3r on Jul 15, 2017 6:59:01 GMT
they heard you were coming  ?
Post by R2S on Jul 15, 2017 8:43:32 GMT
Have the gates been unlocked? Plan on being there circa 11:30.
Post by nigel on Jul 15, 2017 9:16:40 GMT
Have the gates been unlocked? Plan on being there circa 11:30. Open ☺
Post by nigel on Jul 15, 2017 9:22:06 GMT
Post by nigel on Jul 15, 2017 12:07:23 GMT
Post by nigel on Jul 15, 2017 13:16:07 GMT
