Post by nakedbee on Feb 11, 2017 16:08:36 GMT
So i've finally got around to gathering up enough parts to start this Exocet journey. I picked up my chassis about eight months ago and immediately got to work on the floors and bulkheads. It only took a few hours when I had nothing else I could do without the miata bits. Picked this beaut up for $500, 203K on the odometer, non runner. I never intended to use the Miata drivetrain so this was perfect. Four hrs later...
Post by nakedbee on Feb 11, 2017 16:11:59 GMT
Post by nakedbee on Feb 11, 2017 16:16:09 GMT
Post by nakedbee on Feb 11, 2017 16:28:27 GMT
So whats going in here you ask... As per the name of the thread my intentions are to use a GM 4cyl Ecotec motor and to utilize the entire drivetrain from a solstice/sky. My goal is to find the Kappa platform that uses the "PPF", generally I'm seeing them on late 2007+ models. Now I know there is swap kits for the engine utilizing that gawd awful oil pan and the motor mounts from ecotecmiata.net which hopefully I will not have to use but if I have to then so be it but @ $750 for an oil pan! I hope I can just modify the miata subframe. Now for the remainder of the drivetrain I plan to modify the the Kappa parts to fit. During my research I have found that the Kappa platform to be both longer in wheelbase and wider. So hopefully I can just cut down the PPF, have the driveshaft shortened and have the axles modified and shortened as well. As many of you may know, the rear diff used in these cars are the sameish as the other Getrag models just geared to a 3.73 in the G80 model. I may use the getrag mount offered by V8 Roadsters but I hope to be able to fab my own.
Post by nakedbee on Feb 11, 2017 16:36:12 GMT
Post by nakedbee on Feb 11, 2017 16:40:56 GMT
It's a darn close fit but If i get the billet T-stat housing and just run a remote T-stat that will free up at least 2.5" in the back. Now up front if I cut away at the stock subframe or get the V8 Roadsters LW subframe the oil pan will slip right behind the steering rack. To gain a little more clearance I should be able to slightly modify the oil pan on the driver side to get me another inch of up/down clearance.
Post by gwnwar on Feb 11, 2017 20:28:12 GMT
Nice ideas and build so far.. What kind of gains will you get in HP and weight and balance..What add on are available for engine?? Just what are you going to do to the front sub frame looks like you will need to cut a large section out of the whole middle. You will be playing around with structure and steering.. Might be worth buying a proven kit to same time and headaches..
Post by nakedbee on Feb 12, 2017 19:02:29 GMT
The LE5 will put out 200whp 200wtq with minor mods, I'm not exactly sure the engine weight but it's full aluminum. The aftermarket for the Ecotec engines is huge and cheap to boot. Initially I just want to get it up and running on a stock tune, I have HP Tuners so disabling the VATs and other CEL stuff is no problem. After I get her shook down end goal would be a healthy 450-500whp.
Subframe whoes, well either I cut and weld, cheapest option or 1. buy the ecotecmiata oil pan or 2. possibly try and use the V8 roadsters mountless subframe.
Next step from here would be to grab an AR5 transmission and recheck clearances.
Stay tuned.
Post by nakedbee on Sept 10, 2017 21:25:43 GMT
Back from the dead! The new wheels, forget the model but their 15x9 et 0 Seats, steering wheel and belts Battery mount and cable in one Picked up a set of V-Maxx coilovers Fuse block Mocking up the "cluster"
Post by nakedbee on Sept 10, 2017 21:31:57 GMT
Extra stuff... Getting the engine harness ready Security system all installed...lol
Post by gwnwar on Sept 11, 2017 4:06:00 GMT
FYI.. The pics in your last 2 posts are not showing up. photobucket is charging you not to post pics now. Please get another site to use.. This has been covered in the General Chat Section
Post by nakedbee on Sept 11, 2017 14:09:21 GMT
Yeah sorry about that, all fixed now.
Post by rc58 on Sept 11, 2017 16:10:18 GMT
That looks Great. Amazed at your wiring tray and how clean it is. What exactly is your cluster?
Post by nakedbee on Sept 11, 2017 19:27:50 GMT
I'm using a 10" Windows tablet running HP Tuners. Thanks for the kind words, I kind of get OCD about wiring and hate to have even one wire I don't need.
Post by bornwild on Sept 13, 2017 2:36:12 GMT
That cluster is awesome. I'm planning on doing the same thing but running tunerstudio on a raspberrypi and a 7" touchscreen.
