Post by birubhai on Mar 13, 2017 22:08:32 GMT
Many thanks Ed, I will be scouring through all the points you mentioned. Thank you once again. Slow burn as not may parts available in EU so seems US is the way to go. I would like to try just with sliders 18G , just to get feel of what is going on with transmission and in meantime arrange/order an Hit clutch.
Hopefully all should be in place in 2 weeks as an urge for track bike is tempting too. Wishes....
Re sliders, what is the size for Burgman please ?
Cheers for now
Post by edvb on Mar 14, 2017 12:38:46 GMT
Post by birubhai on Mar 14, 2017 16:13:17 GMT
Post by edvb on Mar 14, 2017 19:03:07 GMT
21.85 " is the minimum so you should be ok. Check the faces of the variator with a straight edge to see if they are flat and no grooves on the surface. From what I can tell yours seem ok. My Bell looks the same so the HIT clutch should fit fine if you get it. For me the 18 gram sliders worked very well with the stock setup springs the HIT clutch comes with installed.
Post by birubhai on Mar 15, 2017 10:38:12 GMT
Hi Ed, I have ordered HiT and sliders from the German website. Many thanks.
Not sure if I need to order new belt as it looks fine. Awaiting all parts and will start working in few days.
Post by davej98002 on Mar 15, 2017 17:53:00 GMT
I think I would buy a new belt to install while I had it all apart. But hold on the the used one as a spare. The avarage belt lasts about 20,000 miles. Some have gotten to 30,000 but when it failed it damaged the pulley. Again, BurgmanUSA has reports on belt life.
Post by birubhai on Mar 15, 2017 18:27:26 GMT
Hi, thanks Dave. Will order a belt. Having trouble with clutch nut. Received the adjustable spanner, 600 mm long weigh more than a kilo or two. I have tried to hold the clutch and wrench and smack it on floor, its a good upper chest/shoulder workout but no good.
Post by birubhai on Mar 25, 2017 20:28:19 GMT
Hi, trust everyone is well and looking forward to spring/summer riding. I have been able to install HiT, sliders and Kevlar belt and all looks good; hopefully. Is there any bedding in time or is it ok to be used properly. I did feel acceleration being better and smoother but clutch engages at higher RPM. I don't have an RPM gauge on mine so can't verify. Dr pulley stockist Dirk, suggested to use stock setup first. I have all the helper springs with different spring tension but not sure of the combination. I used a Malossi strengthened torque spring and a helper ring that came with HiT setup. There were 3 torque rings but been advised to use just one by Dirk. I think its a great mod but tuning it would be difficult as don't want to go through taking everything apart again. Will do an acceleration video soon. Best wishes and thank you once again for all your help and direction. Cheers for now
Post by edvb on Mar 25, 2017 21:59:16 GMT
Great to see you get it back together. Setting up the clutch can take a while if you need to lower the rpm for engagement. You will need to find a way to get the RPM of the engine for a baseline before starting. They do make some small ones used for lawn mower engines that wrap a lead around the spark plug wire. They are pretty cheap and probably would work for your application. My weight including myself with a full load of fuel was 579LBS. That worked well for my trike with the 32HP I had on mine. Everyone is different but you need a RPM baseline to make sure you are not over revving the engine. www.ebay.co.uk/itm/Honda-Lawnmower-Generator-Digital-Tachometer-Tach-Hour-Meter-w-RPM-Recall-/252055712895?hash=item3aafb0f47f:g:M4IAAOSw44BYdgzGThe roll bar looks great:)
Post by birubhai on Mar 28, 2017 13:17:33 GMT
Hi, thanks for the link Ed. I placed an order for one. I was looking for coloured ones and found a company Run Leader but it involved connecting to battery, which could have caused some unnecessary drain. The ones connected with spark plug are a bit our on calibration but should give some indication as been advised that anything after 9K is flat out, best performance was at 7.5K (based on last dyno).
I will update once received the unit.
Thanks again
Babr
Post by birubhai on Apr 5, 2017 15:41:38 GMT
Hi, I have received the digital spark plug tacho gauge. However, I am not sure if the wire I am trying to connect it to is spark plug one. Please see attached pics. Appreciate all the help. I spliced the cover as access close to plug point is difficult. I didn't get any readings in the meter after connecting it to the wire (unless its the wrong one).
Post by edvb on Apr 5, 2017 18:46:07 GMT
Post by birubhai on Apr 5, 2017 19:24:02 GMT
Thanks Ed, I think i could be the wrong wire. Will try again tomorrow.
Post by birubhai on Apr 5, 2017 19:42:01 GMT
Many thanks again Ed, it was the wrong wire. Got it working now. There is no instruction with the device. Pressed programming buttons randomly - showing 1230-1240 idle. Does this sound right?
Will do a proper install tomorrow and reseal the conduit I spliced from a different wire.
Thanks a ton.
Best
Post by edvb on Apr 5, 2017 20:05:22 GMT
Yes that is about right.
