Post by Andy Patey on Feb 7, 2011 21:23:57 GMT
Hi mate looking good keep the good work i like Andy
fatboy
Post by fatboy on Feb 16, 2011 18:21:58 GMT
fatboy
Post by fatboy on May 12, 2012 21:46:11 GMT
started to get my head back into gear and see if i can finish the rocket this year wiring done, lights working, engine turns over, will add antifreeze and flue tomorrow and see what happens
Post by Froggy on May 13, 2012 6:22:38 GMT
Good luck today then mate! Post us some pics when your finished!
Post by kiwicanfly on May 13, 2012 7:45:44 GMT
Hi what did you cover your panels with, shown in post 9 ?
Rob
fatboy
Post by fatboy on May 13, 2012 17:22:41 GMT
well started on car at about 9.30 fitted 2 warning lights had to wait in for a guy to collect some fish done by 11.00 then of to halfords to get some antifreeze back home filled system then to my shame as a gas engineer/plumber :-/had 2 leaks had to replace some hose and clips cut a drain hole in floor under tank and fitted a door vent to make it look nice refit fuel tank and put in some fuel connect fuel hoses and primed system THEN TURNED THE KEY WHO'S THE DADDY STARTED FIRST TURN ;D one happy fatboy
fatboy
Post by fatboy on Jun 27, 2012 21:12:04 GMT
I HATE TRYING TO BLEED THESE JUMPED UP COCKEYED REAR BRAKES 3 DAYS SO FAR AND STILL A SPONGY PEDAL
fatboy
Post by fatboy on Jul 3, 2012 20:35:52 GMT
O the joy of kitcars this is what happens when you fit the dash then the seats and find you can't see them for the wheel all done can see the speedo now took me a day to make my exhaust and cost me the grand total of about £80 I'm quite pleased with it the only thing is heat wrap stinks when you get it made a couple of covers for the engine mounts a bit of rubber mat and some vinyl make things look a bit tidier
Post by Deleted on Jul 6, 2012 21:07:04 GMT
Looking good so far, good job! I'm glad I chose white panels for mine.
Post by Andy Patey on Jul 7, 2012 8:52:51 GMT
Hi mate the first start up is a happy day and wone to keep you smiling for a while. the mev is looking spot on have you got a time that you have the kit on the road. Andy
fatboy
Post by fatboy on Jul 7, 2012 17:43:06 GMT
hi andy trying to get it ready to take to RTR next weekend
fatboy
Post by fatboy on Jul 7, 2012 17:50:28 GMT
Quick tip for any one trying to bleed rear brakes go to machine mart and buy your self a easy bleeder after 3 days of prating about with the pumping the peddle method it only took me 15 mins with this piece of kit
Post by Paul (madeye) on Jul 8, 2012 8:36:43 GMT
haha, out of principle i have always avoided easy bleed kits, but i think ill invest as i have seen everyones troubles with bleeding. will save hours of wasted time i think.
Post by Deleted on Jul 8, 2012 9:31:53 GMT
As a bit of advice, check your brake pipes and feeds to the cylinders from the resovoir. Nothing worse than an easy bleed kit spewing it's fluid after a rupture in that area.
fatboy
Post by fatboy on Jul 8, 2012 20:40:59 GMT
been there done that got the t shirt had 2 dodgy fittings when i first started bleeding o dear one may have used a few naughty words >:(and 2 rolls of kitchen roll to clean up the mess
