Post by mikeeyboy on Aug 22, 2017 13:47:04 GMT
Thanks for the offers. John, mine is a mk2 98 so guessing not very relevant.
Paul, where abouts in Huddersfield are you?
Thanks
Post by p2tav on Aug 22, 2017 14:24:41 GMT
Hi,
Skelmanthorpe near denbydale let me know if you want to pop over and I will send you my address,
cheers
Post by Stiggy on Aug 22, 2017 15:25:42 GMT
can we see some pictures of your build please, the previous ones you posted have been lost. Cheers
Post by mikeeyboy on Aug 22, 2017 18:56:26 GMT
Hi start, I intend to but haven't had chance yet.
Paul, my office is in penistone. I could nip over Thursday about 6pm if that's any good?
Cheers.
Post by mikeeyboy on Sept 13, 2017 11:57:51 GMT
It took a bit of time bit I have managed to update all the photos in my thread using the new method. Some may be a little out of order but you get the idea.
Post by mikeeyboy on Sept 21, 2017 21:41:59 GMT
Does anyone know of a good solution for extending or shortening cables? What are people using to shorten them?
I am after a really slim Crimp connector that is barely noticeable - normal electrical crimps add quite a bit of bulk to the cable.
Thanks
Post by buildercg on Sept 21, 2017 22:18:55 GMT
Does anyone know of a good solution for extending or shortening cables? What are people using to shorten them? I am after a really slim Crimp connector that is barely noticeable - normal electrical crimps add quite a bit of bulk to the cable. Thanks I didn't use these because i found them after I did most of my electrical work, but they look like pretty good butt connectors. I have some work to do on my rear harness so they're in my shopping cart now: waiting for "funding". www.amazon.com/dp/B073RMRCC3
Post by mikeeyboy on Sept 22, 2017 13:32:08 GMT
Thanks, they look quite handy, think I am going to order a few to trial and see whether they look a bit more professional than normal butt connectors
Post by mikeeyboy on Sept 30, 2017 20:20:13 GMT
Does anyone know of a good solution for extending or shortening cables? What are people using to shorten them? I am after a really slim Crimp connector that is barely noticeable - normal electrical crimps add quite a bit of bulk to the cable. Thanks I didn't use these because i found them after I did most of my electrical work, but they look like pretty good butt connectors. I have some work to do on my rear harness so they're in my shopping cart now: waiting for "funding". www.amazon.com/dp/B073RMRCC3For anyone else after a good connector for joining wires the ones buildercg recommended are excellent. They do not make the cable any bigger and it remains flexible after fitting. I bought mine Frome eBay and I am going to get some more. You just need a heat gun. In other progress I had been debating whether to bother with a heat shield/drip tray for the fuel tank. I nearly didn't bother but then thought it wouldn't be worth failing over. I spent today bending and welding some sheet into a drip tray. I am using a mk2 tank so it had to sit lower than normal which meant a flat bottomed tray was impossible. I also had to mount it around my exhaust. I am pretty pleased with the solution. All made on a home made sheet bender from scrap angle iron.
I have drilled a hole and welded a small drain tube into the corner. I will probably put some hose on this to route any spilt fuel well away from the exhaust as my setup is very tight I am going to spray the tray black so it blends in. Now onto finishing the wiring!
Post by gwnwar on Oct 1, 2017 17:29:31 GMT
Nice work.. I would not even say anything about it when testing. They might find something wrong with design. Just being there if they look might make them happy.. No need to poke the dog..
Post by mikeeyboy on Oct 2, 2017 15:23:35 GMT
Definitely, there seems to be a lot of "open to interpretation" parts of the manual. On the day I think I will go with the "Ask no questions and you will be told no lies!" mentality.
Post by mikeeyboy on Oct 17, 2017 11:28:43 GMT
Can anyone offer any clarification on the position of the wheel wing mounting locations?
I am planning on fitting them this weekend but I have looked through photos of some completed cars and the front and rear wings seem to be in slightly different positions? Am I imagining this?
The IVA manual does not seem to differentiate between the front and the rear wheels, it just gives 1 set of specs for the positions?
Thanks
Post by Stiggy on Oct 17, 2017 11:51:54 GMT
The requirement is for fronts to cover the trailing edge, rears just need to sit above, see the diagram from the IVA manual.
Post by mikeeyboy on Oct 17, 2017 12:20:16 GMT
Thanks Stuart,
So the 30 degree to the front edge and 50 degress to the rear edge is applicable to both front and rear wheels?
The only other requirement is that the rear edge of all 4 mudguards must be no higher than 150mm above the centre line of the wheel?
So to be clear, all 4 wheel guards can be mounted in the same positions as each other?
Sorry if this seems like a stupid question, but it is not easy to reverse so want to get it right first time and I keep reading the IVA manual trying to work out what I am missing!
Thanks
Post by Stiggy on Oct 17, 2017 13:26:53 GMT
Yes we need clarification here, when I said "fronts" I meant the front edge not the front wings! Front and rear wings are not refereed to individually so we must assume the diagram is for both.
