Post by boileralum on Mar 23, 2016 22:35:36 GMT
Where is "Matt L." located? I am aware of a success reg. in Columbus area (of a MEV supplied chassis), but not aware of any successes beyond that. I'd love to reach out to this other fella for insight / tips / etc. !! He's north of Bloomington near Martinsville or Mooresville, I think. Matt Leonard is his name. He is in the facebook owners group, has the red & black car FS with the older FM turbo kit.
Post by boileralum on Mar 23, 2016 22:37:58 GMT
Wow, that's a lot going on at once! Keep up the good work on both fronts!
Post by einy on Mar 24, 2016 11:08:45 GMT
Is this Matt Leonard fellow in Bloomington, OH (tiny little town half way between Cincinnati and Columbus on I-71), or Bloomington, IN ?? If Ohio, I need to figure out how to contact him despite not being a Facebook user ...
Post by boileralum on Mar 24, 2016 20:14:56 GMT
Bloomington, IN
I'm also from IN, I see now that my reply may have led you a bit astray. I was trying to convey that IN isn't completely easy to register either.
Post by einy on Mar 24, 2016 21:51:10 GMT
Got it ...
Post by zeitgeist on Apr 16, 2016 0:36:49 GMT
Quick update. Finally got back to wrenching on the Exocet today after weeks of house remodeling work. Now comes 3-3.5 week wait for quartz countertops to come in and some detail stuff to finish but back to working on the car feels good.
I got the bolts torqued with locktite and installed the pedals and pedal braces for the throttle and brake pedal assembly but the clutch is well off aligning so I doubt I will get that one in. New clutch master cylinder, full length SS line and slave cylinder all in.
I ran the SS fuel line kit from FM and re bent the factory brake line running to the rear. This was not too bad and allowed me to mount it and the SS fuel line using rubber protected P clips together along the passenger side lower square tube rail. I had already installed 8 rivnuts and I copied the Crossthreaded peeps idea of using a spacer on the bolt to separate the P clips. Nice and neat install that is secure and out of the way in the tunnel. I'm glad I stuck with keeping the entire brake hydraulic system intact during the tear down and build.
Tomorrow I will tackle the steering column. The Exomotive kit does come with nuts and bolts for the steering column bracket correct?
I can't seem to find any in the boxes from Exomotive.
Post by zeitgeist on Apr 16, 2016 13:44:31 GMT
I forgot to add that I found a glass shop that will cut laminated DOT rated safety glass windshield while looking for frosted glass panels for a house door we are having made. The shop guy said they have aluminum extruded moulding the glass could be fitted to or they can mount the windshield in a rubber gasket like Jeeps or school buses then mounted in a flat steel frame. Good for options.
Post by abc123 on Apr 16, 2016 17:20:04 GMT
mine did not have bolts for the steering column, also didn't see any listed on the packing list.
Post by jon on Apr 16, 2016 18:07:41 GMT
I had to source my own bolts for the steering too. I used some I took off the car somewhere in the tear down.
Post by zeitgeist on Apr 17, 2016 1:39:10 GMT
Post by zeitgeist on Apr 18, 2016 2:21:42 GMT
Installed the radiator today. I got a late start after sleeping in,watching F1 China and going grocery shopping so I didn't start until after 1. Spent about 4 hours and painted the swaybar mount brackets and swaybar. I'll add pictures tomorrow. The Supermiata crossflow radiator is a very nice piece. Mirror finish polished aluminum and all the fittings and bracket mounts are top notch. I ended up mounting the radiator as high as I could and still be able to install the top mount bolts. The fan shroud braces barely touched the swaybar so I clearanced them some for added peace of mind. So now the front swaybar and radiator are done. Tomorrow I start the fuel tank mount process. I haven't decided how I am going to secure it since there has been discussion on how strong the mounts are.
Post by zeitgeist on Apr 19, 2016 0:21:53 GMT
Post by mawdo81 on Apr 19, 2016 20:46:37 GMT
Wish my beer bottle was that large relative to my battery...
Post by einy on Apr 20, 2016 0:14:36 GMT
You need to switch to 22oz bomber bottles, that's all !!
Post by zeitgeist on Apr 21, 2016 19:55:20 GMT
Having some issues installing the wiring harness. How did everyone run the wiring to connect the front harness section to the rear harness section? Did you run the wiring in the car (like factory) or under the tunnel? I thought I saw most people have just one bundle of wiring going over the main horizontal tube from wiring tray to engine bay but I have 2 big bundles. Any pictures would be much appreciated and/or the page in a build thread showing or discussing wiring install. Some build threads that come up in the search are 25+ pages. Thanks in advance.
