Post by Deleted on Aug 17, 2015 18:56:10 GMT
I'm looking at trying to improve my handbrake on my Triabusa. I've got the usual separate hi spec mechanical caliber. It's pants. Just fishing for any ideas and wondering if anyone has fitted anything else that's any better. Cheers in advance
Ads
Post by slugshot on Aug 17, 2015 19:52:06 GMT
I don't know of any cable type that's any better than the spot caliper.
I did ponder the idea of trying a line lock to the rear caliper, this way you keep the cable one on for the MOT in three years time.
Post by Deleted on Aug 17, 2015 20:10:35 GMT
That's my issue. I'd like to keep the mechanical side of things so that's I don't have to mess around when it comes to mot time. (Long way away I know)
Post by andy7b on Aug 18, 2015 9:08:23 GMT
I still use the spot caliper it's not brilliant but ok, I found if you make the caliper 2 mm narrower it helps as it's designed to grab a thicker disk than the standard one we use so the lever necks out, you just have to machine 2mm off the spacers in the middle and put it back together and hopefully it should be a bit better. Andy
Post by Deleted on Aug 18, 2015 9:47:54 GMT
Cheers Andy
