Post by john on Dec 7, 2015 12:43:09 GMT
Great progress must be a real hurdle to have it fired up and running.
Looking at the wiring though just make me realise what's ahead. Any issues or tips ?
Mine is a mk2 and removing abs and airbags of course. Any hidden earths or issues or can you literally cut off everything you don't need and removed the abs bulb?
Post by stevednorris on Dec 7, 2015 14:08:59 GMT
Best tip is to make sure you follow each wire all the way to where your going to cut it. I took all the harness tape off and still managed to cut a couple of wires in after a join so had to re-solder the joint. But apart from that, it was actually less daunting than I thought it would be. I made sure the engine was running before I started cutting then started the engine after every I'd cut a couple of wires just to make sure I hadn't cut anything important.
Post by bigpaul on Dec 16, 2015 17:55:40 GMT
Did you go with the digital speedo in the end? They also do Rev Counters which are backlight so was thinking of giving these a go myself
Post by stevednorris on Dec 17, 2015 8:38:19 GMT
Not yet, I did ask them to send me a copy of the fitting instructions so I could see what inputs I needed, but that was 3 weeks ago and I'm still waiting.
Post by bigpaul on Dec 17, 2015 9:03:38 GMT
Ok mate I will do the same and if I have any joy will ping them on, cheers Paul
Post by bigpaul on Dec 18, 2015 12:33:07 GMT
Steve, have the fitting instructions, if you want to ping me your email address happy to send over
Paul.
Post by stevednorris on Dec 18, 2015 16:05:19 GMT
Hi Paul,
PM sent, thank you.
Post by stevednorris on Dec 19, 2015 13:51:21 GMT
Hi Paul, I got the fitting instructions, all seems fairly easy. I've just got to work out if removing the connections to the ecu is going to mess anything up.
Post by bigpaul on Dec 19, 2015 14:53:18 GMT
Yes it doesn't look too bad, seems from their emails also that they feel it's pretty straight forward, was going to have a look at the wiring diagrams for the dash and see if I could see any potential issues
Post by stevednorris on Apr 18, 2016 11:09:39 GMT
I've finished my dash at last. It took a while to sort out the sensors and wiring but it's all now working and reading correctly.
Post by R2S on Apr 18, 2016 12:32:51 GMT
looks really neat, have you thought bout giving the fibre glass face a coat of black wrinkle finish paint to give it a period look. You could leave the rolled edge and top unpainted (careful masking required).
Post by bigpaul on Apr 18, 2016 13:17:47 GMT
Looks great Steve, was it as straightforward as the instructions suggested? What's the USB connector for?
Also bang sticker spot on!
Post by stevednorris on Apr 18, 2016 13:23:43 GMT
I had thought about crinkle paint or turned aluminium but I quite like the matt black finish so I will leave it as it is for the moment.
The dash was easy enough to wire in, I had to get a pressure transducer from the states for the oil pressure and needed a resistor in the fuel guage wiring to get the fuel level correct.
The USB connector is for a sat nav.
Post by bigpaul on Apr 18, 2016 14:59:59 GMT
I wondered if anyone was going to put a radio in one of these yet! thought it might have been ipod connectivity!
Might have to pick your brain on the dials once I get to that stage
Paul.
Post by R2S on Apr 18, 2016 15:06:55 GMT
I have a clarion bluetooth system which I plan to install to the drivers right above the side deck behind a lockable cover.
