Post by subevo on Nov 1, 2009 18:58:20 GMT
hi after a discussion with my other 2 mates we have came to the conclusion that if we were to build another mev car either the rocket or sonic then these points may be of interest.
we were split between which car to build.decided on sonic but for no good reason maybe cause it was newer.
rocket kit is cheaper
rocket has no hassle with bodywork.
sonic needs at least 2 people to install fiberglass sides which have to be removed and installed a few times.no good if you are building yourself with nobody to help.amount of cutting out of fiberglass can be daunting and very time consuming.
in hindsight we agreed the rocket with sonic style roll bar would suit us best.just our opinion for a first time builder.
Post by subevil on Nov 1, 2009 21:39:48 GMT
Both cars look spanking and are light weight. Your right for a first time builder the rocket looks less hassle but i think all kit car builders need a helping hand at some point engine in etc.
Anyone else built one of each 2 of one etc?
Post by nigel on Nov 2, 2009 18:48:02 GMT
I would be easily for me to say the Sonic here but that would be an untruth.
I like both, ;D and I think its a personal issue weather you prefer the Exo skeleton look or the bodied look.
Both cars share the same engineering principles and base donor, although I'm sure over time both will be fitted with more exotic and extreme power plants.
Both use the same successful time served 7 principles while manage to dare to be striking and innovative in terms of style and donor components used.
I think it would be a close call as to which would be easer to build, and remember in terms of cost. Savings can be made more easily on the Sonic as many items are hidden from sight, thus allowing the builder to exploit less expensive components i.e. the Exhaust System / Silencer as an example.
Personally I don't care which one anyone pic's, so-long as they enjoy it, because lets face it, enjoyment is what its all about.
Nigel
[And I just don't know where this discussion is going to go once the Missile is launched] ;D ;D ;D
