Post by kiwicanfly on Jan 16, 2015 23:02:43 GMT
Double check before you buy a steering wheel quick release, they push the wheel towards you so may be an issue if you are already snug.
Post by deanohonda on Jan 16, 2015 23:08:02 GMT
after iva throw colapsable boss away will give u extra clearance 1 of those many bits that falls off after iva ;-) lol
Post by carlyd on Jan 16, 2015 23:13:49 GMT
Do the Sparco and OMP steering wheels come with the boss to fit the ford column or do I need to buy that seperate?
Post by deanohonda on Jan 16, 2015 23:27:59 GMT
If u can hold off a couple off weeks i have a omp boss u can borrow along with moded engine cover & iva compatible exhurst lol ;-)
Post by carlyd on Jan 17, 2015 9:10:45 GMT
If u can hold off a couple off weeks i have a omp boss u can borrow along with moded engine cover & iva compatible exhurst lol ;-) My iva won't be for a year or so, so I can Deffo wait for that deano thanks :-) Do the steering wheels come with a universal fitting kit for example (for after IVA) ?
Post by carlyd on Jan 20, 2015 15:19:07 GMT
I'm looking at buying seats and a steering wheel as I want to crack on getting everything mocked up so I can send the chassis for powder coating. I have decided on a Sparco 300mm steering wheel but am now stuck for seats. I was considering the GRP seats package from KitPartsDirect.com but wanted to speak to someone to confirm a few things. I called their number and got an 'invalid number' message, I checked and dialed several times. I called another number of their website and was given a mobile number by a receptionist (who says they are nothing to do with KitPartsDirect.com) so I called that number an get the 'invalid number' message again. Plus I tried to place an order online and you can't pay online, you have to send a cheque. I don't own a cheque book Does anyone know if they have gone under? if so is there anywhere else that I can buy the seats package below. GRP Padded Seat Setup Discount_PackI managed to strip my engine and have sent a few bit for powder coating etc. I am using a company to powder coat the rocker cover in a dark red and then carbon fibre dip it. The effect looks amazing.. red carbon fibre. I haven't seen it anywhere else before so looking forward to getting that back. I have cut out the floor and am fixing with 4mm rivnuts when it's back from powder coating. I borrowed this idea from kiwicanfly I knew the focus seats would come in handy for something. I have drilled the holes but won't be fitting rivnuts untill back from powder coating. cdn image serverupload image sites
Post by carlyd on Jan 20, 2015 15:23:29 GMT
Oh I have also made a small floor for the front too. I will be covering both with carbon fibre sheet as the aluminium was scratched to death, even with the protective coating.
Post by Deleted on Jan 21, 2015 13:48:45 GMT
Post by carlyd on Jan 21, 2015 14:14:48 GMT
Got it, thanks Steve
Post by carlyd on Jan 22, 2015 14:22:22 GMT
I took my engine to be reconditioned today, they are completely reconditioning everything, regrinding valves & seats,head skim, camshaft regrind, crank regrind with new bearings, new piston rings and rebore, all new seals and gaskets etc. the cost £1,350 + vat. I am taking my time with the build and want to use quality parts only etc so didn't want the engine packing up after the lengthy build. It had better be like a new one at that price.
For 'IVA' I will be buying a NEW gearbox so I can put it on a new plate.
Post by airforceone on Jan 22, 2015 16:00:37 GMT
I know the Honda engine is a good one BUT..
A new 1.8 zetec is £700 and a new 2.0 zetec is £850, these prices include delivery and come with a certificate stating they are new. Also have a flywheel and new clutch fitted to them.
You will be close to £1600 for your Type R recon.
With 220BHP and a nice high revving V-Tech it will be worth it.
Post by carlyd on Jan 22, 2015 17:18:49 GMT
I was thinking the same, a new 2.0 ford engine with bike carbs will give about 170 bhp and come in at almost £2k. I get an extra 50BHP for free and the extra revving of the VTECH. Plus it's easier (and cheaper) to get close to 300BHP with the Type R engine than the focus engine. I get the VAT back as I'm buying everything through my business.. that's already saved me the price of the engine recon!
Post by mawdo81 on Jan 22, 2015 17:26:22 GMT
Check re the Iva though as I believe amateur builds have different requirements to professional builds and that might be an issue...
Post by carlyd on Jan 22, 2015 17:31:54 GMT
Check re the Iva though as I believe amateur builds have different requirements to professional builds and that might be an issue... It's just a recon of the engine making it 'New' spec using genuine Honda parts so shouldn't be an issue. I will check though cheers.
Post by mawdo81 on Jan 22, 2015 17:58:44 GMT
I meant re the vat and the business buying the parts etc. loads have had work done so that isn't the issue I'd be concerned about.I
